NE1 know whrere I can find LH bolts for OEM ring gear? #904829
01/14/11 11:31 PM
01/14/11 11:31 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
Installing a SG in a formerly open 741 chunk. A few of the ring gear bolts seemed to have bottomed out when installed at the factory. When I removed them the first 1/4" of threads were messed up on some of them. I don't know if I should just replace the messed up bolts or order a bottoming tap to clean up the ring gear. Any suggestions?
I do need some new bolts though...
Russ:)
BigBlock 74 Swinger
Re: NE1 know whrere I can find LH bolts for OEM ring gear? [Re: bb74swngr] #904830
01/14/11 11:53 PM
01/14/11 11:53 PM
Connecticut
biginchmotor Offline
Connecticut
Try this Mopar part #: P4529163...John.
Re: NE1 know whrere I can find LH bolts for OEM ring gear? [Re: bb74swngr] #904831
01/15/11 11:26 AM
01/15/11 11:26 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I bought a quality bottoming tap and it wouldn't even scratch that steel. I had to grind the bolts shorter and reuse them. They took the correct torque so should be OK. Some pretty crappy quality control from Mopar.
Russ:)
Re: NE1 know whrere I can find LH bolts for OEM ring gear? [Re: dmerc] #904832
01/15/11 03:36 PM
01/15/11 03:36 PM
Missouri
mopar addict
mopar addict
Missouri
Thank you David! Think I will do just as you did and take some length off the bolts. I tried using a punch to mark the two bad holes and flattened the punch each time...that is some hard stuff. You saved me some $ on taps and I really appreciate the time you took to comment. Take care:)
Russ...
Russ:)
BigBlock 74 Swinger
