04, 5.7 plugs and wires.. #904770
01/14/11 10:45 PM
01/14/11 10:45 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
Hello, what the labor time for doing all 16 plugs and wire..
what does all-data say.......
Geesh this thing was a pain in Booty... esp the ones near the booster........... and tem darn plugs didnt wanna come loose..... i am darn sore...... dont care if i see another one lol
Re: 04, 5.7 plugs and wires.. [Re: Dakota_Don] #904771
01/14/11 11:13 PM
01/14/11 11:13 PM
okla.
sam64 Offline
sam64  Offline
okla.
the 04 5.7s in my 65 coronet and 68 cuda would be 2o min each tops.besides if you already have it done yourself you saved money right?
Re: 04, 5.7 plugs and wires.. [Re: Dakota_Don] #904772
01/15/11 08:25 AM
01/15/11 08:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kid changed the plugs in his 04 Ram in about an hour.I hope you used a dab of antisieze on the threads and some dielectric grease on the boots.Rocky
Chrysler Firepower
Re: 04, 5.7 plugs and wires.. [Re: therocks] #904773
01/15/11 12:08 PM
01/15/11 12:08 PM
Alton, IL
Alton, IL
yes and yes .. he changed all 16 in a ram?
Re: 04, 5.7 plugs and wires.. [Re: Dakota_Don] #904774
01/15/11 12:22 PM
01/15/11 12:22 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
They're not as bad as it looks, it takes me about 30-45min if I gap them first, they're all pretty straight forward except the ones near the brake booster, on those I stack a few short extensions in the hole and pull them out 1 by 1.
Re: 04, 5.7 plugs and wires.. [Re: MoparJoe] #904775
01/15/11 12:47 PM
01/15/11 12:47 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
put on a lift, remove plastic inner fenders and stand up to do it, it's much easier on the back. I can do all 16 in under an hour this way start to finish.
that plug wires mess is a whole nudder story in itself
Re: 04, 5.7 plugs and wires.. [Re: gtx6970] #904776
01/15/11 02:31 PM
01/15/11 02:31 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes it was all 16.We also put a dab of antisieze on the coil over bolts.Makes sure they come out easy the next time.Rocky
Chrysler Firepower
