5.9 magnum swap with painless efi a/c or no a/c? #90434
07/18/08 04:42 PM
07/18/08 04:42 PM
Andrewh Offline OP
Andrewh  Offline OP
So I got a 5.9 magnum with a/c on it.
Just curious if you were going to swap a 5.9 into your car and use the efi, would you keep the a/c or figure out a way to remove it?
keep the a/c or not
single choice
Votes accepted starting: 07/18/08 03:42 PM
Re: 5.9 magnum swap with painless efi a/c or no a/c? [Re: Andrewh] #90435
07/18/08 04:54 PM
07/18/08 04:54 PM
Andrewh Offline OP
Andrewh  Offline OP
the reason I ask is, if you have no a/c, and there is no heater valve, it will make a difference on where the water temp sensor is located.
So I was just trying to get a feel for the number that would keep a/c or just want a flat out motor with efi.
Though I have no idea how hard it would be to find the parts that are required to drop the a/c on a serpentine belt motor.
Re: 5.9 magnum swap with painless efi a/c or no a/c? [Re: Andrewh] #90436
07/18/08 04:59 PM
07/18/08 04:59 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
if you drop the A/C its just a belt change.
I'd keep it.
I still like sitting in line to get into the nationals and watching everyone sweat like pigs..... and I'm thinking about putting a jacket one...:D
Re: 5.9 magnum swap with painless efi a/c or no a/c? [Re: Andrewh] #90437
07/18/08 07:50 PM
07/18/08 07:50 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
Depends on where you live ( how hot is it ) and how much you will drive it on the street?.
like said if you dont want to use it get a belt for none A/C
Re: 5.9 magnum swap with painless efi a/c or no a/c? [Re: Sub95] #90438
07/18/08 09:15 PM
07/18/08 09:15 PM
Andrewh Offline OP
Andrewh  Offline OP
I plan on using it. I was sort of taking a pole for them to see if it was a likely choice. Since it makes a difference on where to put the sensor.
