Fuel Line Insulation #90425
07/18/08 03:18 PM
07/18/08 03:18 PM
Northampton Pa
65 NSS 500 Offline OP
Northampton Pa
Any one have any suggestion for insulation for a fuel line. Need tonight cant order by mail.Im looking for something to insulate the metal fuel line . Mine runs by the header and gets to hot. I wanted to go to car cruise tonight and I need to get something to cool/insulate this. Any thoughts
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: Fuel Line Insulation [Re: 65 NSS 500] #90426
07/18/08 03:43 PM
07/18/08 03:43 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
tin foil
Re: Fuel Line Insulation [Re: 65 NSS 500] #90427
07/18/08 03:43 PM
07/18/08 03:43 PM
Andrewh Offline
Andrewh  Offline
thick wrap of aluminum foil should help. Not a permanant fix, but should hold you over.
Put some like wall insulation around it first, then wrap it in aluminum foil.
Re: Fuel Line Insulation [Re: 65 NSS 500] #90428
07/18/08 04:05 PM
07/18/08 04:05 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
This guy sells quality heat shield products at a decent price. I've got it all over my engine compartment on fluid lines and sparkplug boots. Some of the sparkplug boots are squished between the header pipe and inner fender - no burn through.
http://stores.ebay.com/KPPerformance_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
I used this on the fluid lines. You can tuck the ends under like spark plug boots or buy some of his high temp heat shrink tubing. -
http://cgi.ebay.com/ebaymotors/KP-Perfor...63995QQtcZphoto
Re: Fuel Line Insulation [Re: Lefty] #90429
07/18/08 05:11 PM
07/18/08 05:11 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I quick fix might be to take some rubber hose (fuel line, heater hose) and split-cut it along it's length and tie wrap it around your fuel line.
Re: Fuel Line Insulation [Re: 65 NSS 500] #90430
07/18/08 05:19 PM
07/18/08 05:19 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Any one have any suggestion for insulation for a fuel line. Need tonight cant order by mail.Im looking for something to insulate the metal fuel line . Mine runs by the header and gets too hot. I wanted to go to car cruise tonight and I need to get something to cool/insulate this. Any thoughts
Just go to Ace and buy their gray insulating "foam wrap". It is pre-sliced so you can just cut it to the proper length and easily install on your hard lines. Works great for insulation !
PS - it also has the added benefit of "infuriating" the purists - so ? Function over form, right ?
Re: Fuel Line Insulation [Re: IronWolf] #90431
07/18/08 05:25 PM
07/18/08 05:25 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I used some of the pipe insulation foam that is basically a split foam tube that you use to wrap the pipes under your house to keep them from freezing. I used the smallest ID I could find, and then wrapped that with some of that metal duct tape - not the cloth stuff, the real METAL tape that you use on AC ducts. That stuff made all the difference - the foam would shrink and blister without the tape, and that fuel line is about 6-8" from the headers.
Clair
Re: Fuel Line Insulation [Re: Clair_Davis] #90432
07/18/08 05:37 PM
07/18/08 05:37 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
home depot has metal tape backed with 1/8" sticky rubber stuff. did some older ford pickup lines that way. looks pretty nice too. in the furnace/water heater section somewere
