chrysler techs need help #904037
01/13/11 11:04 PM
01/13/11 11:04 PM
Central NY
GarageDodge Offline OP
Central NY
My son has a 2008 ram 1500,went to start it wont turn over,dash lights up,battery fully charged,if he unhooks battery &then hooks it back up it will start right. This has happened twice in the last 3 months,dealer has no idea,I say must be in the security system or pcm,sorta hard i am in ny hes in fla. any help is appreciated,thanks.
Re: chrysler techs need help [Re: GarageDodge] #904038
01/13/11 11:17 PM
01/13/11 11:17 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
usually if its security it will disable the spark or fuel...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: chrysler techs need help [Re: GarageDodge] #904039
01/13/11 11:20 PM
01/13/11 11:20 PM
ill
dennismopar73 Offline
ill
replace key
or use another key
Re: chrysler techs need help [Re: GarageDodge] #904040
01/14/11 12:59 AM
01/14/11 12:59 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Typically this is due to "lockup" of the WCM/SKREEM (wireless control module), There is a TSB for this.
The easy way to tell if that IS the problem is to see if the keyless entry is also not functioning (If it has keyless) as when the WCM goes non responsive, the keyless entry will also quit.
Pulling the IOD fuse (number 11 under hood IIRC) for at least 10 seconds will clear the WCM and verify the problem if it starts after this (No need to discon the battery)
What causes this is static discharge from the person thru the key, it locks up the module and you are done.
The module will have to be replaced with the updated one to fix it.
Reference TSB 08-007-08
The keys have NOTHING to do with this as even with a bad or incorrect key it will still start and die 3 times before security lockout will prevent cranking
Rick
Blown71X V2.0 under construction 71 Cuda 383 4-SPD (maybe for sale) 2010 Challenger B5 Classic
Re: chrysler techs need help [Re: Blown71X] #904041
01/14/11 11:43 AM
01/14/11 11:43 AM
North Central Indiana
C-Tech Offline
C-Tech  Offline
Rick
Listen to Rick he knows what he is talking about
Kevin
Re: chrysler techs need help [Re: C-Tech] #904042
01/14/11 02:37 PM
01/14/11 02:37 PM
Central NY
Central NY
Thanks for the help Rick,yes the keyless wont work when this happens,passed this info to my son.thanks again Joe.
Re: chrysler techs need help [Re: Blown71X] #904043
01/15/11 12:10 AM
01/15/11 12:10 AM
ill
ill
dumb question,,
if this went to a dealer ,, why didnt the
dealer fix this issue?
they know of this tsb
maybe just waiting for warranty to expire??
i disrregarded the tsb because it had been to a dealer?
Re: chrysler techs need help [Re: C-Tech] #904044
01/15/11 01:32 AM
01/15/11 01:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Rick
Ah come on Rick is just another dumb Chrysler tech. Just fooling as I know he knows his stuff. Ron
