Re: Do all 8 3/4 rear ends have an inner seal. [Re: Chilort] #901953
01/12/11 05:32 PM
01/12/11 05:32 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
here you go
metal gasket #2881314
foam gasket #2070933
I wonder if Mopar still has them. They've not been able to get much for me lately.
you can get them from fel pro still , there is a thread with the numbers posted somewhere .
Re: Do all 8 3/4 rear ends have an inner seal. [Re: RapidRobert] #901954
01/12/11 05:42 PM
01/12/11 05:42 PM
scratchnfotraction Offline
I have 3 axles that have good ones you can have a set,i will stay with the greens and wont need them
just need to get them pressed/cut off
give me a yell later
Re: Do all 8 3/4 rear ends have an inner seal. [Re: JohnRR] #901955
02/05/11 09:38 PM
02/05/11 09:38 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
here you go
Foam - FEL-PRO Part #13800
Steel - FEL-PRO Part #55032
Re: Do all 8 3/4 rear ends have an inner seal. [Re: Chilort] #901956
02/05/11 09:52 PM
02/05/11 09:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
As of last Tuesday, reproduction wheel bearing adjusters and retainers are available for the first time.
Re: Do all 8 3/4 rear ends have an inner seal. [Re: DoctorDiff] #901957
02/05/11 10:44 PM
02/05/11 10:44 PM
Cookeville
Chilort Offline
Chilort  Offline
Cookeville
Yay!!!!! I don't need them but maybe it will help keep people with the correct bearing in their 8 3/4!!
