Will the heat kill my alternator? #901887
01/11/11 06:39 AM
01/11/11 06:39 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
Am worried about the heat killing the alternator.
If I wrap the pipes, wategate pipes and exaust pipe that will run next to the alternator will that be enough?
Cheers gg408
Re: Will the heat kill my alternator? [Re: gg408] #901888
01/11/11 03:41 PM
01/11/11 03:41 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You've got that downpipe going the wrong way. It needs to go straight up through the hood like a locomotive.
You can see my 130 amp alternator tucked under the header on the far side of the engine. It ran for several thousand miles with no issues. I had a header leak that was burning the wires off the alternator but it kept charging.
- Stu Harmon
Re: Will the heat kill my alternator? [Re: gg408] #901889
01/11/11 05:38 PM
01/11/11 05:38 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I have a turbo blanket and can lay your hand on it. The down pipe is wrapped in exh wrap and can touch it. Do both those and the alt will be fine.
Re: Will the heat kill my alternator? [Re: TheOtherDodge] #901890
01/12/11 12:19 PM
01/12/11 12:19 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
Same here i have a turbo blanket( black colored) from VSracing.net..they are a sponsor on turbomustangs and the t-6 ones are like around only $100 now and a very nice piece...also my down pipe is wrapped with no alt problems...Its a world of difference in heat when u put that blanket on along with dp wrapped
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Will the heat kill my alternator? [Re: dodge turbo] #901891
01/12/11 04:25 PM
01/12/11 04:25 PM
Houston, Texas
Houston, Texas
Here is a pic where you can see the blanket and wrap on the downpipe.
Re: Will the heat kill my alternator? [Re: TheOtherDodge] #901892
01/13/11 04:31 AM
01/13/11 04:31 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
Thanks for that guys.
Suppose I can try it and see what happens.
Any particular wrap to use or are they all the same?
Cheers gg408
Re: Will the heat kill my alternator? [Re: gg408] #901893
01/18/11 12:46 AM
01/18/11 12:46 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
what is your manifold/turbo setup there? who's alt brackets?
Re: Will the heat kill my alternator? [Re: j.mcconnell] #901894
01/22/11 12:10 AM
01/22/11 12:10 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
The exaust manioflds are fabbed by me out of straight steam pipe & bends and so is the merge pipe.
The turbo is a BWS475 modified and fitted with an 80mm comp wheel .
The alternator brakets are again fabbed up by me. All I did was mount the alternator of the bottom timing cover hole with a long bolt and some spacers and then just made a braket that runs from that bolt to a bolt on the water pump.
Cheers gg408.
Re: Will the heat kill my alternator? [Re: gg408] #901895
01/22/11 06:34 AM
01/22/11 06:34 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
That wont be fun changing the belts
