Page 2 of 7 1 2 3 4 5 6 7
Re: procharged smallblock [Re: 80arrow] #901660
01/19/11 08:00 PM
01/19/11 08:00 PM
Alberta Canada
madmoparmike Offline
Alberta Canada
thanks for posting my question for you is what all did you you get from SD concepts? what harmonic dampener are you running?
how much did this stuff cost?
i am looking for a package that i know will work and i dont have to go threw the R&D
Re: procharged smallblock [Re: madmoparmike] #901661
01/19/11 10:57 PM
01/19/11 10:57 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I bought the complete kit from them, it was a used one that one of their customers had and decided to upgrade, so it had all the brackets. The bottom pully is a billet piece that is designed for a ATI dampner and has two grooves for the alt. belt. One thing to think on is how you're going to package it. My set-up is on the passenger side, others are on the drivers. Not saying one is better then the other but they both have pluses and/or minuses.
Re: procharged smallblock [Re: 80arrow] #901662
01/20/11 10:05 PM
01/20/11 10:05 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
I'm currently putting a F1R on a small block mopar. It was a kit that places the procharger on the passenger side. My kit was from SD Concept Engineering.
More info please!
Im doing the same thing in a 68 barracuda, and using a Sd bracket as well
Let me know what you want, I'll tell you whatever I know. It might not be right but I'm new to this also.
Im looking for more pics if you have them, maybe of the pipe routing and intercooler mounting?
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: procharged smallblock [Re: 80arrow] #901663
03/14/11 09:55 PM
03/14/11 09:55 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
I'm currently putting a F1R on a small block mopar. It was a kit that places the procharger on the passenger side. I believe that you can get brackets from Steve Morris for a small block. Another good site for info is Yellow Bullet. My kit was from SD Concept Engineering.
Any updates on your build?
Re: procharged smallblock [Re: Cudahlr] #901664
03/15/11 08:21 AM
03/15/11 08:21 AM
8
80arrow Offline
80arrow  Offline
A little bit. I oredered the cam, carb, hat, and meth injection from Morris a few weeks ago, still wating on the meth kit. The cam should be showing up at the engine builder this week or next. He ordered the top end last week from Indy. He's waiting on the pistons and dampner so he can balance the rotating assembly. I've been working on my car quite a bit but its all little stuff, mounting the fuel pump, figuring out where I want to run the lines, mounted a trans cooler in the rear of the car, made a new support that goes from the hood latch down to just below the rad. Trying to figure out how to get the electronics placed inside and wired to look decent. Sent my procharger in to Procharger and had them go trough it and make sure everything is good, mostly for piece of mind. Got the rad mounted and more cage put in the car, it'll cert to 8.50 now.
Re: procharged smallblock [Re: 80arrow] #901665
03/15/11 08:33 AM
03/15/11 08:33 AM
8
80arrow Offline
80arrow  Offline
Seems that I'm not smart enough to post pics yet today
Re: procharged smallblock [Re: Cudahlr] #901666
03/15/11 08:35 AM
03/15/11 08:35 AM
8
80arrow Offline
80arrow  Offline
Cudahlr,
Hows yours coming?
Re: procharged smallblock [Re: 80arrow] #901667
03/15/11 08:11 PM
03/15/11 08:11 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
sometimes its just moparts somehow forgeting the upload, i usualy use a host like photobucket and then just link the pic with the imagecode shown under the pic, im a pc for dummies kind of guy but it works pretty good and is easy if you want to be able to acces the pic from somewhere else or just link it to multiple sites:)
Re: procharged smallblock [Re: 1Fast340] #901668
03/15/11 09:00 PM
03/15/11 09:00 PM
8
80arrow Offline
80arrow  Offline
maybe this will work??
There is about 1/2" between the rad and the brace, can't relly see that here.
Re: procharged smallblock [Re: 80arrow] #901669
03/15/11 09:03 PM
03/15/11 09:03 PM
8
80arrow Offline
80arrow  Offline
2
Re: procharged smallblock [Re: 80arrow] #901670
03/15/11 09:04 PM
03/15/11 09:04 PM
8
80arrow Offline
80arrow  Offline
3
Re: procharged smallblock [Re: 80arrow] #901671
03/16/11 01:10 AM
03/16/11 01:10 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
New cars pack stuff much tighter than that. As long as nothing moves you should be fine.
- Stu Harmon
Re: procharged smallblock [Re: 80arrow] #901672
03/16/11 08:48 PM
03/16/11 08:48 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Cudahlr,
Hows yours coming?
Not as good as I hoped, work slowed down a bit here so it's taking a bit longer, I got a few more pieces, like the C&S carb, fuel pump, and the intercooler. And I have all the pipe routing and mounting locations figured out
Re: procharged smallblock [Re: Cudahlr] #901673
03/16/11 09:15 PM
03/16/11 09:15 PM
8
80arrow Offline
80arrow  Offline
What intake are going to run on yours?
Re: procharged smallblock [Re: 80arrow] #901674
03/16/11 09:20 PM
03/16/11 09:20 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Either the M-1 that I have, or a super victor.
Re: procharged smallblock [Re: Cudahlr] #901675
03/17/11 02:02 AM
03/17/11 02:02 AM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
The Super Vic is what I have. It really breathes.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
Re: procharged smallblock [Re: Stroker Scamp] #901676
03/18/11 12:13 PM
03/18/11 12:13 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
starting to gather ideas on a sb build, where should i begin to look for ideas,on internals of the block, any help with heads would help too
Are you interested in SB Ford power? I know of a motor that went 6.67/212 with a 135 that is priced to sell.
Re: procharged smallblock [Re: BobR] #901677
05/26/11 01:54 AM
05/26/11 01:54 AM
pacific northwest
Stroker Scamp Online content OP
Stroker Scamp  Online Content OP
pacific northwest
anyone running a F2?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: procharged smallblock [Re: Stroker Scamp] #901678
05/26/11 10:42 AM
05/26/11 10:42 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Guys, the biggest mistake you can make is to just talk to one guy because someone thinks they are the best. The other HUGE mistake I made during my turbo build was over thinking every aspect of the build. Do good research and listen to everyone. You will slowly figure out who REALLY knows what they are talking about. They are usually the ones that make you work for teh information and they dont just blabber on about what they know
Re: procharged smallblock [Re: joshking440] #901679
05/26/11 10:02 PM
05/26/11 10:02 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
I fully agree!
