TTI headers v. el cheapo
#90155
07/18/08 02:59 AM
07/18/08 02:59 AM
Posts: 2,112 New Jersey, US of A
PlumCrazy73Dodge
New Jersey, US of A
does TTI's small block headers have a different bend to them than the cheapos? I know they have a lot better flanges and are a lot better....do they hang down the same hieght as the cheapos?
I have a 318 with summit headers and they scrape the ground when you hit a dip in the road sometimes if its a wierd dip......did not want to fork out dough to scrape up nice headers...
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust 73 Cuda - Triple Black 340 4 speed MIKE
Re: TTI headers v. el cheapo
[Re: RobX4406]
#90157
07/18/08 04:10 AM
07/18/08 04:10 AM
Posts: 5,337 the house on the left.
cogen80
Dougs and tti fit up tight.
The most all the cheap ones are copies of hookers. they almost all hang below the steering gear on the drivers side.
[Re: cogen80]
#90158
07/18/08 06:42 AM
07/18/08 06:42 AM
Posts: 1,756 London, England
Gavin
London, England
Yup, to be honest ground clearance was the reason I went with TTI's over cheapo's. I had enough of scraping my bottom over every bump!
[Re: PlumCrazy73Dodge]
#90163
07/18/08 10:55 AM
07/18/08 10:55 AM
Posts: 666 Anywhere the British Secret Se...
Moonraker
Go cheap in an A-body and you'll regret it most cheapo's fit like crap in A bodies, and require heavy mods in some cases, atleast on the drivers side, and hang way to low to boot. The passenger side is cavernous compared to the drivers and cheapos work there fine in most cases. To bad you couldnt buy headers individually and go TTI for the drivers and cheap on the passenger side . I bought TTI's for the Duster and was very pleased with the fit, just a few minor mods since all cars are not built exactly the same. But if you like a challenge and want to save some dough go cheap, but whats your time worth to you. Your working with a B or E-body it looks like from your sig so cheapos fit quit a bit better in those body styles.
[Re: Moonraker]
#90164
07/18/08 11:47 AM
07/18/08 11:47 AM
Posts: 1,978 Southaven, MS
BossRide
Southaven, MS
I asked this same question a year or two ago and one guy told me he would pick up cans on the side of the road to raise money for TTIs before he bought another set of cheapies... that always stuck in my head as being funny and probably true.
So I turned down a free pair of Hooker headers and saved and bought a set of TTIs and they are awesome. They were worth the wait and price. They went right in, have some huge flanges, I didn't have to jack up the motor or ding anything to get them in, and I'm running my stock starter. The only thing that ever scrapes are the collector flanges but my car sits pretty low.
Save, purchase, and be happy.
The Blue Goose
My instagram: Bossride
#90167
07/18/08 02:14 PM
07/18/08 02:14 PM
Posts: 357 The Garden State
LimelightCuda
The Garden State
I have Hedmanns with a BB/e body. They hit the steering box. I had to put in manual steering. I'm having arm problems so I'm going back to PS. I'm either going to have to smash up the headers or save up for TTIs. Thanks for the info.
Phil
1970 Barracuda Gran Coupe 1970 A66 Challenger Convertible
[Re: BossRide]
#90170
07/18/08 03:10 PM
07/18/08 03:10 PM
cogen80
i know i always thought they were too much money until i finally broke down and bought a set. and like that guy that will pick up cans from the side of the road my car will sit until i save the money for a set . will not use that hooker,headman junk again.
[Re: CHRYCOFAN]
#90172
07/18/08 04:56 PM
07/18/08 04:56 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Listen to Rob above.....Check out the Dougs.
We put a set of Dougs on a Duster back in the 70's & I remember how the tubes ran.....exactly like the TTI's I have on my Dart. The one tube on the driver side was a slip tube & went around the T-bar just like the TTI's & they didn't run under the steering linkage.
If they're the same now (and I think they are )they're cheaper, still have thick flanges & 16 ga tubing. A buddy just put a set of Dougs on a B motor 66 B-body& they fell in.
TTI basically copied the Dougs as far as I'm concerned. If I'd looked more back when I bought my TTI's I'd have Dougs there instead.
Check them out.
Butch
No slip tubes on the Dougs SB A's anymore. No trouble for me getting a mini-starter without messing with the header flange bolts.
Hard to beat Dougs for fit AND price.
IMO, tti are overpriced for what they are. I've really never found the step tube to 1 3/4" to be a significant advantage from a performance standpoint. If tti's were the same price as Dougs... I'd buy Dougs!
[Re: RobX4406]
#90173
07/18/08 06:22 PM
07/18/08 06:22 PM
PlumCrazy73Dodge
New Jersey, US of A
Will do thanks...info was good
