stalls while idling #90053
07/17/08 10:07 PM
07/17/08 10:07 PM
Northwest PA
BassMan Offline OP
BassMan  Offline OP
Northwest PA
I have a 1975 slant 6 auto Duster that will start fine but once in a while stalls while idling and won't restart for several minutes. It seems to run down the road fine except for this arbitrary stalling. I've changed plugs, ballast resistor, ECU and fuel filter. I thought it was the choke so I disconnected the auto choke and put a manual choke on it. Any ideas??
Re: stalls while idling [Re: BassMan] #90054
07/18/08 12:22 AM
07/18/08 12:22 AM
I have a 1975 slant 6 auto Duster that will start fine but once in a while stalls while idling and won't restart for several minutes. Any ideas??
At that point hold the coil wire 1/4" from metal & crank w key on & see if it's spark or fuel related. Are you using gasahol? (10% ethanol)
