Re: Horsepower TV 360 budget build show? [Re: 70AARcuda] #900375
01/09/11 07:21 PM
01/09/11 07:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have a 91 360 roller block and no where to mount the crank sensor.
I have heard some of the early magnum blocks had PR oil holes drilled but none of them I have had apart had them.
It would not be rocket science to drill and tap a hole in the block and run it into the shaft, they do it all the time on big blocks for some reason.
Re: Horsepower TV 360 budget build show? [Re: HotRodDave] #900376
01/09/11 07:28 PM
01/09/11 07:28 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
P4876907 360 Short Block Assembly — 1.58" Comp. Height
that is what this shortblock is...you can see the mount for a crank sensor on the back of the block
Tony
70 AARCuda Vitamin C
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900377
01/09/11 08:42 PM
01/09/11 08:42 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Looked like a MP crate shortblock to me, late model crank and block and a 4.020" bore with coated skirt pistons are some things that point me in that direction.
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900378
01/09/11 09:49 PM
01/09/11 09:49 PM
How do you get LA heads to oil properly with a magnum block?
drill horizontle into the rear of the head thru the threaded boss to the rear pedestal then spot face inside the pedestal in the threads to get a hole started to drill downward at an angle to meet the hor passage. Feed it from the oil psi sending port at the top rear of the block & T off of it to feed both heads. I'd have to check my notes but iirc I drilled an .080" passage at the top. This is a good mod for ANY eng as it lets you restrict the 5 vertical passages from the crank to the cam to 1/16" (drill/tap for a setscrew and drill the set screw to 1/16") as that is all the oil the cam bearings need and cam bearings are a major wasted leak point and contributes to oil starvation probs on rods fed from mains that feed the rockers from the cam (#4 on a BB)
Re: Horsepower TV 360 budget build show? [Re: RapidRobert] #900379
01/09/11 10:30 PM
01/09/11 10:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
get the right set of heads for the right block and dont have all those problems...KISS
Tony
Re: Horsepower TV 360 budget build show? [Re: 70AARcuda] #900380
01/09/11 10:45 PM
01/09/11 10:45 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I love Joe's comment on the 442 horsepower and 467 ft lbs of torque, "For what we got here that's very respectable." They should have fallen on their head that's probably the highest they've ever gotten that dyno. That's some serious power and torque for such a mild 360, and they didn't even tune the carb.
Re: Horsepower TV 360 budget build show? [Re: 70AARcuda] #900381
01/09/11 10:55 PM
01/09/11 10:55 PM
I dont consider them probs only unmet challenges and the satisfaction when you fix/solve/change it (outside the box) is tremendous plus a person may have a set of killer LA heads ready to go and there is still the prob of the cam oil leaks.
Re: Horsepower TV 360 budget build show? [Re: 70AARcuda] #900382
01/09/11 11:48 PM
01/09/11 11:48 PM
Southwestern Ontario Canada
racealittle Offline OP
Right set of heads is the obvious answer. I paid large for those heads and the world changed. I tried to sell them and got very ridiculous offers. Heads that support over 500 hp easy with a mild motor won't be given away by me.
I need to see how the mods to the oil system are done, then I can do the work.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900383
01/09/11 11:59 PM
01/09/11 11:59 PM
Hightstown, NJ
njdevil2 Offline
njdevil2  Offline
Hightstown, NJ
I saw part of that episode. I hardly EVER watch Horsepower, only because it really is a Ford/Chevy info-mertial. The first thing I said was (like every one else) where did they get this for $450. The heads alone were that much. And why is it they always do a "cheap build" for a Mopar? This is the second one, I thought. Too much BS and Muscle Car is starting to become a joke as well.
Sure we could pick apart this one episode, but, geez, most of the stuff I saw was either unrealistic (alum head, electric water pumped long block for $450) or just plain stupid (re-used the rings? [Edited by Moparts - Family Friendly Site - Keep it clean]?).
A hone job and new rings are cheap, you've already put the new bearings in it, whats a couple more bucks for rings.....
1970 road runner Convertible
1 of 179
Re: Horsepower TV 360 budget build show? [Re: njdevil2] #900384
01/10/11 01:16 AM
01/10/11 01:16 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Here is a pick of my 360 '94 Magnum block, from a Ram 1500
I'll be putting LA style heads, note the oiling passage an d crank sensor mount
Dan [image][/image]
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900385
01/10/11 01:21 AM
01/10/11 01:21 AM
I was told that the block would have to be drilled correctly for oil to supply the LA heads. The very few motors that I know of that have attemped that kind of oiling mod, have always had problems. I have a very good set of LA MCH cnc eddies that I would like to use on a roller cam magnum block.
It'd depend on where you tapped the block for pressurized oil but I could see it being difficult. DO THE HEADS, it was real easy exc for a slight bit difficult starting the angled hole inside the pedestal. That way you can use your investment. I didn't take pics & might be awhile b 4 I get back over there.
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900386
01/10/11 10:13 AM
01/10/11 10:13 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I will have to go back and watch the episode but I think those roller lifters had a link attaching them together, even if it was a magnum block still had aftermarket lifters.
Yes, it had aftermarket, linked roller lifters.
I am a big block guy and don't know all of the small block tricks.
dunno how hard it would be for a machine shop to set up and drill the oil galleys in the #2 & #4 cam journals like an LA, but RapidRobert has another good option, plumb them externally, like Indy does with their SR & 440-1 heads....
or just be on the lookout for an '89-91 360 block, they're TBI LA's with roller cams, or if you can sacrafice .090" of bore, any LA 318 '85-up is a roller cam motor....
or use a non-roller block and retrofit lifters....
2017 Grand Cherokee Overland
Re: Horsepower TV 360 budget build show? [Re: patrick] #900387
01/12/11 12:41 AM
01/12/11 12:41 AM
Utah
fast360 Offline
fast360  Offline
Utah
Yeah it's really hard to believe that they got that motor for 450$. I did a 360 build very similar and it cost me around 4,500, although i was pleased to see they almost made 450 i was hoping thats what mine would hit. I haven't had a chance to even start mine yet:(
