How to ID a 360 harmonic balancer #89994
07/17/08 07:54 PM
07/17/08 07:54 PM
Mississippi
bcr Offline OP
bcr  Offline OP
Mississippi
We have a wobbling balancer on a 360. It is the one that came with the 360 Commando crate engine bought some years back. He has another balancer that is made different, so how do you determine if it is compatible with a 360? I think the other is from a 318.
Re: How to ID a 360 harmonic balancer [Re: bcr] #89995
07/17/08 08:18 PM
07/17/08 08:18 PM
Mississippi
bcr Offline OP
bcr  Offline OP
Mississippi
I scrolled down to the topic about the 340/360 damper question and clicked on the link showing the pics. These LOOK like the two pictured as compatible, although diff in appearance, but are there any numbers or methods to really know?
Re: How to ID a 360 harmonic balancer [Re: bcr] #89996
07/17/08 08:23 PM
07/17/08 08:23 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Did you go to the 360 damper picture on this page? http://www.moparts.org/Tech/Archive/smallblock/5.html
either of the 2 pictured for the 360 are compatable with the 360. There may be one offset bolt hole on one or the other but it is no big deal to file it out as 5 out of the 6 will line up.
Re: How to ID a 360 harmonic balancer [Re: MoparforLife] #89997
07/17/08 09:16 PM
07/17/08 09:16 PM
Mississippi
bcr Offline OP
bcr  Offline OP
Mississippi
up.
Yes, thanks, that is the link I mentioned in the above post. So these were both used on an external balance? Dont use any bolt holes anyway as it is a race only application.
Re: How to ID a 360 harmonic balancer [Re: bcr] #89998
07/18/08 04:18 PM
07/18/08 04:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Both of the balancers pictured serve the same function but go about it in different ways, one style adds weight to externally balance while the cavity in the other style removes the same amount of weight 180° opposite.
Notice the location of the keyway in relation to the weight/cavity.
Re: How to ID a 360 harmonic balancer [Re: John_Kunkel] #89999
07/18/08 10:44 PM
07/18/08 10:44 PM
Mississippi
bcr Offline OP
bcr  Offline OP
Mississippi
Saw that very thing on the two we have, thanks a lot, John.
