mechanical temp guage on 318 #89896
07/17/08 05:25 PM
07/17/08 05:25 PM
Anonymous OP
Anonymous OP
Where does sensor go for mechanical temp guage on a 318 block? Do you r/r the oem one on the intake or is there a place in the block?
Thank you thank you thank you for responding to my dumb questions!!!
Re: mechanical temp guage on 318 #89897
07/17/08 05:34 PM
07/17/08 05:34 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
put it on the intake so its in the coolant passage
Re: mechanical temp guage on 318 [Re: west] #89898
07/17/08 05:37 PM
07/17/08 05:37 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Only problem with taking the OEM one out is that you will have to drill and tap it for the mechanical sender to fit. You have to keep the probe in the flow of the coolant so don't use a stack of adapters to get it to fit. With the adapters you will not a constant flow and a risk of air pockets forming giving erroneous readings.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: mechanical temp guage on 318 [Re: MoparforLife] #89899
07/17/08 06:44 PM
07/17/08 06:44 PM
Anonymous OP
Anonymous OP
Is there somewhere else besides intake to put mech sending unit? Head? Block?
Re: mechanical temp guage on 318 #89900
07/17/08 06:59 PM
07/17/08 06:59 PM
P
Paul_Fancsali Offline
P
Use a heater hose port use a bell and or T and it will work fine and not have issues with air pockets
Re: mechanical temp guage on 318 [Re: Paul_Fancsali] #89901
07/17/08 07:27 PM
07/17/08 07:27 PM
Upper Midwest
Upper Midwest
As long as you have the heater water valve open so that you get a constant flow rather than a back flush. You need flow and with a tee and in the heater hose the only way to get flow is to have the water valve open. It may work for you but it may not and may not be accurate.
Re: mechanical temp guage on 318 #89902
07/17/08 08:08 PM
07/17/08 08:08 PM
take out one of the extra 3/8" pipe plugs that are in the intake close to the thermostat which is where you want it.
