Belts and Pulleys on a 318 #89891
07/17/08 05:23 PM
07/17/08 05:23 PM
Anonymous OP
Anonymous OP
Rookie Mopar Gut here again. It doesn't look like the belts and pulleys are correct on the 72 Satellite I just bought. The alt. belt goes to crank pulley only, therefore extremely close to waterpump. The powersteering belts goes around ps pump, water pump and crank pulley. The water pump pulley only has 1 groove. Should it have 2 so that the alt. belt goes around it?
Re: Belts and Pulleys on a 318 #89892
07/17/08 05:33 PM
07/17/08 05:33 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Every small block I've ever owned, has had the belt on the alt/water pump/ crank pulley. Then the PS around the crank pulley. I'ts evan that way on the A/C cars exept the alt. has two grooves and two belts and now they add the A/C compressor to that alt./H2O pump/crank configuration.
Re: Belts and Pulleys on a 318 [Re: mopowergtx] #89893
07/17/08 05:39 PM
07/17/08 05:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
On the other hand if it works leave well enough alone.
Re: Belts and Pulleys on a 318 #89894
07/17/08 05:46 PM
07/17/08 05:46 PM
NH
72challorange Offline
He's Game
He's Game
NH
Do you have a pic of the set-up?
Tom
Here is my set-up for comparison.
By tdavist, shot with DSC-P72 at 2008-04-17
Re: Belts and Pulleys on a 318 [Re: 72challorange] #89895
07/17/08 06:42 PM
07/17/08 06:42 PM
Anonymous OP
Anonymous OP
Thanks for the pic!! Great help. My ps pulley lines up with front groove on crank pulley and water pump pulley. The front groove lines up with these pulleys as well. It looks like my alt. is too far back.
