Page 10 of 11 1 2 8 9 10 11
Re: LA built cars, lets find out more, More info needed. [Re: autoxcuda] #897722
10/27/13 06:12 PM
10/27/13 06:12 PM
X
xx29 Offline
xx29  Offline
X
Here's a LA tag that was sitting on a table of a swap meeter. Took a picture for Barry collecting tag info.
What's A48 ?
Dress up group= extra moldings
Re: LA built cars, lets find out more, More info needed. [Re: autoxcuda] #897723
10/27/13 06:17 PM
10/27/13 06:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Thanks Steve!
Paul,
Hard to see for sure, does that tag have a B55 for C55 typo?
Re: LA built cars, lets find out more, More info needed. [Re: NV69B7RR] #897724
10/27/13 07:20 PM
10/27/13 07:20 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
In regards to the fuel tank vent hoses. My 1971 Duster (LA car) had the 4 rubber vent lines and shield but none of them originally had clamps on either end, they were all just pushed on. Of course being an A-body there were lots of other differences such as a different vent line shield design, etc.
Re: LA built cars, lets find out more, More info needed. [Re: ScottSmith_Harms] #897725
10/27/13 07:45 PM
10/27/13 07:45 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's a low mile, not messed with 71 340 Demon, LA built, california sold.
With clamps.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: LA built cars, lets find out more, More info needed. [Re: autoxcuda] #897726
10/27/13 08:34 PM
10/27/13 08:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It appears that you are looking at the one line that is the fuel line, the vent lines are hidden behind it and likely don't have clamps? Have any other pics?
Here is my example, one clamp is missing because I just removed it and replaced the hose for a picture without the old clamp (you can see the indented area where the second clamp had been), the shield had never been off my car before I removed it for this pic, it was untouched with unbroken factory undercoating on all of the bolts that retained it. Also, none of the vent lines were KV hose, they were more generic looking with dimensions and other codes printed on them, they were so nice I cleaned and reused them.
Re: LA built cars, lets find out more, More info needed. [Re: ScottSmith_Harms] #897727
10/27/13 08:38 PM
10/27/13 08:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: LA built cars, lets find out more, More info needed. [Re: ScottSmith_Harms] #897728
10/27/13 08:38 PM
10/27/13 08:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
c
Re: LA built cars, lets find out more, More info needed. [Re: ScottSmith_Harms] #897729
10/27/13 09:39 PM
10/27/13 09:39 PM
Kentucky
fc7freak Offline
fc7freak  Offline
Kentucky
Scott Here are a couple of shots of my Duster
Re: LA built cars, lets find out more, More info needed. [Re: fc7freak] #897730
10/27/13 09:41 PM
10/27/13 09:41 PM
Kentucky
fc7freak Offline
fc7freak  Offline
Kentucky
One more
Re: LA built cars, lets find out more, More info needed. [Re: fc7freak] #897731
10/27/13 09:57 PM
10/27/13 09:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Interesting! Must have come two ways. Can you post your fender tag info?
Re: LA built cars, lets find out more, More info needed. [Re: ScottSmith_Harms] #897732
10/27/13 10:32 PM
10/27/13 10:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It appears that you are looking at the one line that is the fuel line, the vent lines are hidden behind it and likely don't have clamps? Have any other pics?....
Good point. That is my only pictures. Troy might remember though.
Re: LA built cars, lets find out more, More info needed. [Re: autoxcuda] #897733
10/28/13 03:54 PM
10/28/13 03:54 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
I had clamps on my car.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: LA built cars, lets find out more, More info needed. [Re: Troy] #897734
10/29/13 02:44 AM
10/29/13 02:44 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Which side of the trunk lid is the jack instructions on an LA built '69 B-body driver's or passenger's or center?
Re: LA built cars, lets find out more, More info needed. [Re: Alaskan_TA] #897735
10/29/13 12:14 PM
10/29/13 12:14 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
i have started to remove the undercoating on my'69 Dart.
The front wheel wells are black paint under the undercoating and yellow over spray under the black paint.
The rear wheel wells are just yellow over spray under the undercoating.
Would this be a case of standard blackout paint on the front wheel wells only, prior to receiving the full undercoating or would it suggest the under coating was not factory and was applied after the car was purchased?I have not started the floors yet.
Re: LA built cars, lets find out more, More info needed. [Re: can.al] #897736
10/31/13 07:09 PM
10/31/13 07:09 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
I pulled the tank from my car and found this between the pad and the tank... Is this a tank part number tag????
"It takes a Mopar to catch a Mopar”
1970 Challenger T/A 4 speed EV2
Re: LA built cars, lets find out more, More info needed. [Re: MoparJunkie] #897737
11/04/13 06:41 AM
11/04/13 06:41 AM
MoparJunkie Offline
MoparJunkie  Offline
Anyone help with identifying this tag????
Re: LA built cars, lets find out more, More info needed. [Re: MoparJunkie] #897738
11/04/13 10:40 PM
11/04/13 10:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
b
Re: LA built cars, lets find out more, More info needed. [Re: MoparJunkie] #897739
11/04/13 10:50 PM
11/04/13 10:50 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
What car?
Re: LA built cars, lets find out more, More info needed. [Re: ScottSmith_Harms] #897740
11/04/13 10:53 PM
11/04/13 10:53 PM
MoparJunkie Offline
MoparJunkie  Offline
My 70 U code Challenger R/T.
Re: LA built cars, lets find out more, More info needed. [Re: MoparJunkie] #897741
11/04/13 10:56 PM
11/04/13 10:56 PM
MoparJunkie Offline
MoparJunkie  Offline
Barry, thanks. I figured it was... Just curious.
