Dodge/Chry Techs - Oil Change reset - '08 Sebring #89753
07/17/08 11:12 AM
07/17/08 11:12 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Need to go ahead and change the oil in our '08 Sebring. Light 'dinged' with the 'change oil' message. What is the procedure on these cars for resetting the service? Can it be done through the dash, or does a scan tool HAVE to be hooked up?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Dodge/Chry Techs - Oil Change reset - '08 Sebring [Re: GoodysGotaCuda] #89754
07/17/08 02:13 PM
07/17/08 02:13 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
I don't think you need a scan tool...i am not at work right now ,where i could ask one of the techs.i'am pretty sure that u turn key on to access. press on gas pedal 3 times the turn key off...hope this helps...Alan
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Dodge/Chry Techs - Oil Change reset - '08 Sebring [Re: racerAL] #89755
07/17/08 02:51 PM
07/17/08 02:51 PM
Fla
birdboy Offline
birdboy  Offline
Fla
RACERAL is correct
Re: Dodge/Chry Techs - Oil Change reset - '08 Sebring [Re: birdboy] #89756
07/17/08 08:58 PM
07/17/08 08:58 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks!
2020 RAM 1500
Re: Dodge/Chry Techs - Oil Change reset - '08 Sebring [Re: GoodysGotaCuda] #89757
07/17/08 09:09 PM
07/17/08 09:09 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
If the car has Navigation it's in the nav menu.
On my Charger it I leave it draining for a while it resets itself, must have an oil level sensor somewhere.
Re: Dodge/Chry Techs - Oil Change reset - '08 Sebring [Re: MoparJoe] #89758
07/17/08 09:34 PM
07/17/08 09:34 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Nope, no Nav on this one. Thanks
2020 RAM 1500
