Re: LA built cars, lets find out more, More info needed.
[Re: Alaskan_TA]
#897585
01/13/11 09:35 PM
01/13/11 09:35 PM
Posts: 3,054 USA
b54406barrel
USA
Y16 cars had SO / VONs assigned at the factory.
If a dealership ordered a car for stock it would have the number from that page of the order pad.
There are exceptions. One as an example would be a 999 paint car, the number from the pad would have been superceded by a new number with a letter prefix.
So, the order number isn't really all that useful. I wonder if the plant number 162... on my tag was for rr's, all 'b' bodies, or all cars made at the plant? Hmmmm ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Alaskan_TA]
#897588
01/14/11 03:35 PM
01/14/11 03:35 PM
Posts: 3,054 USA
b54406barrel
USA
That answer is no.
Order pads had sequential numbers, but the order forms were for only one type of car in most cases, so the last six numbers can & do repeat across model lines with no relation at all to the other models.
I know of 1970 Barracudas & Challengers with 162xxx numbers also.
Well, now i know what that number means, anyway. Thank you! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: gomangoRTSE]
#897591
01/18/11 02:38 PM
01/18/11 02:38 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Now Ive seen it mentioned here that floor panels may be a little different than other plants? Seems I have heard this before, but I dont know if its accurate. My car is up on a rotisserie now and I am lucky to have superb floor boards. California cars had that piece of metal behind the passenger side wheel wheel that bolted on where your return lines were near. I had a picture awhile back that showed this and I "believe" not sure that it protected the thing that the lines went thru. I can picture it in my mind but cant explain it. Sorry for the clumsiness.
I'll check my one LA car's floor vs. my Hamtrack cars later tonight.
The plate you are talking about is behind the passenger side wheel well. It unique to 1970 California cars. It protects the EVAP lines. The plate changed in 1971 to a different design.
[Re: gomangoRTSE]
#897592
01/18/11 02:39 PM
01/18/11 02:39 PM
Posts: 106 Poland
willard
Poland
[Re: redwrydr]
#897598
01/20/11 03:30 AM
01/20/11 03:30 AM
Posts: 155 Northern California
redwrydr
Northern California
A pic of the LA Cuda fender tag...I thought it was different that it had another tag upside down instead of next to it...anyone else seen that done? ![](http://img38.imageshack.us/img38/1945/img1222uw.jpg) By redwrydr at 2011-01-19
[Re: gomangoRTSE]
#897599
01/20/11 03:34 AM
01/20/11 03:34 AM
Posts: 27,485 So Cal
autoxcuda
So Cal
Ah yes thanks for the larger pic Barry. Appreciate it as I can see much better. Now this shield has two bolt holes in front that attach it to the rear of the fenderwhell opening. I seem to remember seeing two holes. Was this attached with screws that were six sided, or with a phillips head, or what? In the pic there also seems to be perhaps one screw not attached to the frame?
Troy probably will remember. His 70 T/A was ECS.
I think the picture above is his FT6 car and his restoration/detailing work??
[Re: autoxcuda]
#897600
01/20/11 04:54 AM
01/20/11 04:54 AM
Posts: 106 Poland
willard
Poland
I asked Barry a couple of weeks ago about that 3rd attachment point for the ECS shield and he said there was no third screw. The shield was fastened with only 2 by the wheel well. In my car it was like on the pictures and I was also looking for the third screw.
