A street roller cam ?
#893551
01/01/11 01:46 PM
01/01/11 01:46 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Hey guys.....
some people say a solid roller cam is not a good thing to drive in the streets, as the valve train wears quickly.....I had my eye on a .620 lift roller.........
True or false ? what do you say? Dan
Re: A street roller cam ?
[Re: Wedgeman]
#893552
01/01/11 02:14 PM
01/01/11 02:14 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Like the White with poultry or seafood , it sounds like a nice choice. Some guys will tell you " beer " , and they wouldn't be wrong. Solid rollers require a little more scrutiny than a hydraulic flat tappet cam , but like everything else in life , you get what you pay for. If you want a " put it away wet " street car , I wouldn't recommend going down this road. If you don't mind running the valves a couple times a year and require enhanced performance , then it is a natural choice. They will require more money up front and on the back side , as they will be harder on springs and the lifters will require more frequent rebuilding / replacement. But I have had solid cams that liked frequent spring changes. Complimentary parts help here. I had a 429 S.C.J. with that heavy intake valve and nothing lightweight but the Harland Sharp's to open them...........springs every season , and they would let me know when they were on the way south by acting like a rev limiter when they got weak. Lots of solid rollers on the streets these days.........but not many being run by the lazy or weak.
[Re: Wedgeman]
#893554
01/01/11 02:47 PM
01/01/11 02:47 PM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
I have a solid street roller in my challenger and I like it. I am getting ready to put together a 408 small block for my 69 dart that I drive every day in the winter and I think I will put a solid roller in it just to see if those people who say it can not be done are right. V-16 caddys had solid rollers and that was in the 30s. My advice to running a solid roller on the street is buy GOOD rockerarms like T@D or jessel,good lifters and very good valve springs.
[Re: Wedgeman]
#893555
01/01/11 03:24 PM
01/01/11 03:24 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
all of my cars are street cars. they all have solid rollers. it is true, they are hard on springs. you also need very good rocker arms. i have broke so many in the past i now use t&d,s and jesel,s. have not had anymore failures. i do still replace springs often thou...
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Cab_Burge]
#893558
01/01/11 04:00 PM
01/01/11 04:00 PM
Posts: 1,532 off the grid
340B5
off the grid
Springs for endurance racing? Here's a chance for me (and others) to learn. How are they different?
Yeah, it's got a smallblock.
[Re: 340B5]
#893560
01/01/11 05:02 PM
01/01/11 05:02 PM
Posts: 836 Missouri
galen
Missouri
I am rebuilding my engine after loosing a roller at 2500 miles. I lost it because of errors on my part. Not stiff enough a pushrod for the lobe profile and not enough spring. My comp 943-16 springs lost between 20 and 25 lbs. pressure in 2500 miles. This time going back roller with a different lobe profile, (more street friendly) better pushrods and (like the guys said) Endurance springs. Getting good advice and doing my homework this time around. I know the material in the Isky springs I am running this time around is different but I am no expert. Hopefully the spring guys will chime in.
[Re: 340B5]
#893561
01/01/11 05:13 PM
01/01/11 05:13 PM
tubtar
St. Paul , Mn.
I am going to guess that it is materials and tempering done to achieve specific spring rates. Typically , a drag motor will have a more radical lobe and higher r.p.m. than your usual endurance application.......I am thinking road race here. nascar is a different beast because there are short track motors and super speedway motors , but both leave a pile of paper weights after 500 laps. But an endurance spring is not going to need much over 600 lbs open pressure I bet. Pro stock , super stock and comp are nearer 1000 lbs.
[Re: Wedgeman]
#893564
01/03/11 12:39 AM
01/03/11 12:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'll be running a solid roller in my 416 drag week car which will race and drive... I'll have 240 seat pressure and about 640 open... if I had a little higher pressure at open I would run that but I have these spring(and they're new)... check out PAC springs.... too light of a spring and it'll cost you BIG TIME
[Re: Cab_Burge]
#893566
01/03/11 06:13 PM
01/03/11 06:13 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
To the OP, as you can see, its a balancing act. How much race time vs. How much street time? And how much maintenance do you want to be on the hook for? I think you can build a pretty bad-ass street/strip motor with a solid flat-tappet for a lot less, and have a lot less to worry about. Putting the $$ difference into port work on the heads, or a top-end converter might even yield similar gains (?).
[Re: Mofopar]
#893570
01/05/11 01:44 PM
01/05/11 01:44 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Seems like everyone is putting solid rollers in the same bucket. This is not the case...
There are roller profiles that fit a specific need. Some are very aggressive and require more valve spring load at a given lift. There are also lobe profiles that have nice opening and closing ramps that don't need the same spring. For example, I've been using Comp Cams extream street roller profiles with very good luck. They don't require a huge spring and I find that they rarely need ajusting.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
