Re: A street roller cam ?
[Re: gregsdart]
#893572
01/05/11 08:55 PM
01/05/11 08:55 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
What do you guys think about running a Hyd Roller Cam and solid roller lifters? This way the profile means more manageable spring loads but the RPM benefit of a solid lifter. The cam does not know the difference. I also get concerned about getting enough oil on the lifter axles at idle.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
