how fast with a stock 6.1 hemi? #892187
12/31/10 01:57 AM
12/31/10 01:57 AM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, has anyone ran their 6.1 hemi conversion e body at the strip? Just curious what a stock 6.1 will run in a 3900lb e body. 12.5s?
Re: how fast with a stock 6.1 hemi? [Re: 70VcodeCoronetRT] #892188
12/31/10 02:14 AM
12/31/10 02:14 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I just typed it into http://www.mymopar.com/qmet.htm which is a 1/4 mile performance calculator and it says around 12.2s but that is probably an absolute perfect pass.
Re: how fast with a stock 6.1 hemi? [Re: MuuMuu101] #892189
12/31/10 08:55 AM
12/31/10 08:55 AM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
watched a charger srt8 run 13.09 with only 600 miles on her. traction was the problem, and they weigh around 4000-4100.
Re: how fast with a stock 6.1 hemi? [Re: hemibeep] #892190
12/31/10 11:12 AM
12/31/10 11:12 AM
Nebraska
Nebraska
It's kind of strange with all the conversions going on I can't seem to find any real world numbers. Must be more of a cruiser conversion.
Re: how fast with a stock 6.1 hemi? [Re: 70VcodeCoronetRT] #892191
12/31/10 11:16 AM
12/31/10 11:16 AM
Newton, KS
70B5Cuda Offline
70B5Cuda  Offline
Newton, KS
3900# e body?!? Isn't that really heavy-especially with a 6.1? I think the stock weight on a B/RB E body is 3400-the 6.1 weighs at least 150# less than the big block so my guess would be 3250# with a 6.1.
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: how fast with a stock 6.1 hemi? [Re: 70B5Cuda] #892192
12/31/10 11:18 AM
12/31/10 11:18 AM
NY usa
540challenger Offline
NY usa
Stock big block can be up there. I think a 6.1 e-body would be around 3400-3600 pounds.
Re: how fast with a stock 6.1 hemi? [Re: 540challenger] #892193
12/31/10 11:50 AM
12/31/10 11:50 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I am planning on my cuda to be 3200 lbs with me in it and full of fuel. Its gonna have a RMS coil over suspension , Aluminum gen3 Hemi Hemi, T56 Transmission ,8 3/4 rear , lightweight seats ect. ect. I think I should be able to reach my goal. Remeber the 6.1 is slightly lighter than a small block .
Re: how fast with a stock 6.1 hemi? [Re: johnscudashop] #892194
12/31/10 11:58 AM
12/31/10 11:58 AM
NY usa
NY usa
True but a ALum head and intake Small block should be the same weight if not lighter. Please keep us posted on you rbuild i am heading in the direction you are. With my Challenger.
RMS suspension, T/A Hood, I was thinking of going the 6.4 L route but i am waiting to see how much a production crate engine would cost the current 6.4 motor is way out in left field right now.
Re: how fast with a stock 6.1 hemi? [Re: 540challenger] #892195
12/31/10 03:55 PM
12/31/10 03:55 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
The 3900lb was with me in it. My 70 RT SE was just under 3700lbs. But thats with a stock 383, ac and power everything including windows. How much does a crate 6.1 hemi weigh?
Re: how fast with a stock 6.1 hemi? [Re: 440forPOWER] #892196
12/31/10 03:59 PM
12/31/10 03:59 PM
Newton, KS
70B5Cuda Offline
70B5Cuda  Offline
Newton, KS
The 3900lb was with me in it. My 70 RT SE was just under 3700lbs. But that's with a stock 383, ac and power everything including windows. How much does a crate 6.1 hemi weigh?
According to one of the magazines that did the swap, the 6.1 is about 125#'s lighter than the SMALL BLOCK (add more for a big block). Approximate weights of different E/B bodies are in the tech archives.
Re: how fast with a stock 6.1 hemi? [Re: 440forPOWER] #892197
12/31/10 04:01 PM
12/31/10 04:01 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I tried asking that question and the best I could get was 720lbs crated. Someone told me that the 5.7L HEMI weighs less than a 340. So it's somewhere around there. I would guess around the weight of a 340 or 360 or even less maybe.
Re: how fast with a stock 6.1 hemi? [Re: 70VcodeCoronetRT] #892198
12/31/10 06:13 PM
12/31/10 06:13 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
With traction & the right gear & tune, 12.5 is very doable, imo. My bro's 6.1 Magnum went 13.4 & 106 bone stock @ Infineon raceway & my reaction time was average. If your Ebody is a cuda, I'd think mid to high 12's is certain. GOod luck
Re: how fast with a stock 6.1 hemi? [Re: Triggerfish] #892199
12/31/10 07:25 PM
12/31/10 07:25 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
Any inside info on when these will be available? http://www.autoguide.com/auto-news/2010/...t-pri-show.html
Re: how fast with a stock 6.1 hemi? [Re: 440forPOWER] #892200
12/31/10 08:48 PM
12/31/10 08:48 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Now: http://www.bouchillonperformance.com/BPEGS75600.asp
Or if you think you can handle it, take the "440" out for a spin:
http://www.bouchillonperformance.com/BPE440ENGINE90.asp
Re: how fast with a stock 6.1 hemi? [Re: MuuMuu101] #892201
12/31/10 09:59 PM
12/31/10 09:59 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
That one is like $4000 more than the MP one. But I like.
Re: how fast with a stock 6.1 hemi? [Re: 70VcodeCoronetRT] #892202
01/01/11 10:06 PM
01/01/11 10:06 PM
12.5s?
Should be about right. Maybe better with slicks and optimum rear suspension.
My '71 Barrauda weighed 3,260 with smallblock/904 and 3,440 with BB/727. I'd guess the 6.1 would be real close to the smallblock in weight.
Re: how fast with a stock 6.1 hemi? [Re: 70B5Cuda] #892203
01/02/11 03:56 AM
01/02/11 03:56 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
if i remember a 5.7 weighs 485#
Re: how fast with a stock 6.1 hemi? [Re: dangina] #892204
05/09/11 10:07 PM
05/09/11 10:07 PM
Nebraska
Nebraska
Re: how fast with a stock 6.1 hemi? [Re: 440forPOWER] #892205
05/10/11 11:10 AM
05/10/11 11:10 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Part number is P5155513, and they're shipping now.
Rich H.
Esse Quam Videri
Re: how fast with a stock 6.1 hemi? [Re: 70VcodeCoronetRT] #892206
05/12/11 08:45 PM
05/12/11 08:45 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Took my stock 6.1 SRT8 6speed Challenger to the chassis dyno this weekend...layed down 389 rwhp and 385 rwtq. This car ran 13.51 at 107 in the August heat in Florida.
The next car up on the dyno was a new 392 Challenger automatic...layed down a 428 rwhp and 425 rwtq. This car had 600 or so miles on it and the owner showed me his time slip of 12.91 at 110 mph. This is with a 2 seconds plus 60 ft time. Both cars ran on stock tires and weigh close to 4200lbs.
I would guess that a 70 E-body at 3500 lbs with a a decent tire should go 12.50s or quicker even with Betty White driving!!!!!!!!
