Tips/extensions for electric cut outs
#890909
12/28/10 11:02 PM
12/28/10 11:02 PM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
What kind of extensions or tips should I consider using with electric exhaust cut outs? I prefer to have something not angling straight down to minimize dust and fumes. Ideas please.
Re: Tips/extensions for electric cut outs
[Re: cruzin]
#890910
12/29/10 02:33 AM
12/29/10 02:33 AM
Posts: 249 Sonora, CA
68X426
Sonora, CA
I don't run any tip on mine. Dougs 3 inch electric on TTI 3 inch exhaust on a 68 Road Runner. An extension or tip would be visible and I like the hide-away look. I have no issue with fumes or dust. The outlet just points out nearly level with the ground and works perfect. The pressure of the exhaust just blows straight out and no fumes remain, even at idle. If you do want something showing then Summit has about 50 types and styles to choose from.
The 12 Scariest Words in the English Language:
We are here from the Government and
we want to help you.
1968 Plymouth Road Runner, Hemi and much more
1968 Dodge Charger, 318 and not much else
1958 Dodge Pick Up, 383 and loud
1966 Dodge Van, Slant 6 and cool
[Re: cruzin]
#890912
12/29/10 03:31 PM
12/29/10 03:31 PM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
I like the way these enhanced the sound( kind of smoothed and intensified it like horns, trumpets etc)and directed the blast out to the side.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#890913
12/29/10 03:34 PM
12/29/10 03:34 PM
jbc426
West Coast, USA
You can see them from the side if you are low enough.
[Re: jbc426]
#890914
12/29/10 03:35 PM
12/29/10 03:35 PM
jbc426
West Coast, USA
...but not if you are standing nearby. They are the lowest point on the car though.
[Re: feets]
#890916
12/29/10 05:38 PM
12/29/10 05:38 PM
jbc426
West Coast, USA
I agree. I thought they were juvenile until I drove DennisH's car around with them at Hot August Nights. The crowd loved them, and so did I.
[Re: feets]
#890918
12/29/10 10:47 PM
12/29/10 10:47 PM
Posts: 12,814 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
What you do may well depend on where you locate your cut-outs and what under body obstructions are nearby.
On my Cuda, the cut-outs pointed right at the frame rail/crossmember joint. Rather that put a turndown tip on it, I just tacked a small piece of metal to the intersection and curved it down. It protected the frame and floorboard from the heat, got the exhaust from under the car without blowing up a lot of dust and didn't show at all.
Extensions after the cut-outs will noticeably change the sound.
Master, again and still
