Re: big block 590 purple shaft cam spec? [Re: 440Jim] #887548
12/25/10 06:08 PM
12/25/10 06:08 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
i dont know my cc's in my heads. they are uncut so im thinking 90+ cc's so i might have 9.7CR now. the engine is a running,hyd cam combo now that needs some updating. im trying to go faster on a super budget. what if i had a shim headgasket wouldnt that get my CR up? also can deck the block and heads. with the 590 whats the CR limit for pump fuel (93octane)? thanks!
74 dart sport 440 www.Csucarbs.com
Re: big block 590 purple shaft cam spec? [Re: 440Jim] #887549
12/25/10 07:39 PM
12/25/10 07:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
In addition to the actual duration at 0.050", this is what Dwayne Porter measured on one a few years ago.
MP .590 cam, actual measurements----And Mine
DUR. @ ---------Mine
.020=303.5 -----.020=304
.050=270.5 -----.050=272
.100=235.0 -----.100=???
.150=205.0 -----.150=???
.200=177.0 -----.200=179
.250=148.5 -----.250=150
.300=117.0 -----.312=110
.350=76.0 -----.375=50
lobe [Email]lift@TDC[/Email] @105 ICL=.140
LSA 106
I added My actual measurements too.
The .312 and .375 measurements represent duration at .500 and .600 lift with 1.6 rockers. mike
Re: big block 590 purple shaft cam spec? [Re: Sport440] #887550
12/25/10 08:13 PM
12/25/10 08:13 PM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
What would you recommend for rockers and what type of retainer steel or ti.Just curious what you guys recommend.
Kevin
Re: big block 590 purple shaft cam spec? [Re: AAR-B4] #887551
12/25/10 08:49 PM
12/25/10 08:49 PM
Saskatchewan, Canada
barracudabob Offline
What do you guys recommend for valve springs?
Comp 928 or K-Motion 850. My choices.
Would these work with 1.6 rockers as well?
Re: big block 590 purple shaft cam spec? [Re: barracudabob] #887552
12/25/10 09:24 PM
12/25/10 09:24 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Hey Guys,
Has anyone gone from say a .509 hyd. to the .590? How much of a difference would there be given say a 10.5:1 440 fairly ported big valve 906 heads. 3800 pound b-body.
Re: big block 590 purple shaft cam spec? [Re: SILVER67] #887553
12/25/10 09:45 PM
12/25/10 09:45 PM
ONTARIO,CANADA
ONTARIO,CANADA
Hey Guys,
that is kind of the same situation i'm in,but mine is 542ci,915 heads ported,comp?509 hyd and going to a 590 solid,single plane intake and dominator.
Oh ya and the best mine has run was 10.92@123 and trying to get to maybe 10.50
Re: big block 590 purple shaft cam spec? [Re: barracudabob] #887554
12/25/10 09:49 PM
12/25/10 09:49 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I ran the .590 with 1.6's and Comp 928 springs for several years without any issues.
Keith
Re: big block 590 purple shaft cam spec? [Re: SILVER67] #887555
12/25/10 10:03 PM
12/25/10 10:03 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Hey Guys,
I did 20yrs. ago and went from 11.98 to 11.45.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: big block 590 purple shaft cam spec? [Re: 6bblFLASH] #887556
12/25/10 10:15 PM
12/25/10 10:15 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I love the 590! I installed it at 104 in a 3050# DartSport with an 11.2:1 451.
I used Harland 1.6 rockers on the Eddy heads, Isky 8005a springs with steel retainers. Ran 9.90's at 136 MPH all motor. New owner has gone 9.77 in the car.
I never tried advancing the cam more, I wouldn't want to lose MPH and it had PLENTY of torque at 104.
Re: big block 590 purple shaft cam spec? [Re: 6bblFLASH] #887557
12/26/10 10:42 PM
12/26/10 10:42 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
"I too have run and am running the .590.
Lots of people say "theres better cams" I`ve just never found one."
You're kidding, right?
