Page 2 of 3 1 2 3
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886591
12/24/10 10:49 AM
12/24/10 10:49 AM
Under My Car
Mopar_Country Offline
Under My Car
I did the same swap, you should get the throttle bracket from the 340 as well and the upper portion of the throttle pressure linkage. You didn't say what carb, is it a TQ? I run the 340 intake and a large primary TQ on my teen and it runs great. I also did a cam swap and headers. Composite gaskets for the 340 intake. Just make sure your surfaces are clean and dry. On the ends I took the cork gaskets and set them on with black rtv and put a little weight on them and let them sit overnight. Then I put a bead on top before installing the intake, it worked great and no leaks. After installing everything make sure that at WOT your lever on the trans is all the way back but not putting undo pressure on the lever.
Re: got a 340 intake for my 318 RR...what next? [Re: Mopar_Country] #886592
12/24/10 12:18 PM
12/24/10 12:18 PM
Pittsburgh, PA
bigdaddywiz Offline OP
Pittsburgh, PA
thank you so much for all the tips! i will check and see exactly what kind of carb i have when i get home. should i look for any specific markings?
73 Road Runner 09 Challenger R/T
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886593
12/24/10 12:40 PM
12/24/10 12:40 PM
scratchnfotraction Offline
cant miss a thermobog,,it has a plastic bowl center section and is preety big looking
AFB will look like and edelbroke carb..maybe not as pretty
Q-jet looks like ...well a q-jet
I like running a q-jet on all my 318s myself and mopar did use them..so you can find one with a mopar throttle lever too
Re: got a 340 intake for my 318 RR...what next? [Re: scratchnfotraction] #886594
12/24/10 01:31 PM
12/24/10 01:31 PM
Pittsburgh, PA
Pittsburgh, PA
looks like its a Holley...
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886595
12/24/10 01:32 PM
12/24/10 01:32 PM
Pittsburgh, PA
Pittsburgh, PA
and another shot of it...
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886596
12/24/10 01:32 PM
12/24/10 01:32 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Looks to me like you will need a carb.
Re: got a 340 intake for my 318 RR...what next? [Re: MoparforLife] #886597
12/24/10 01:35 PM
12/24/10 01:35 PM
Pittsburgh, PA
Pittsburgh, PA
i wont be able to clean that one up and get it rebuilt?
Re: got a 340 intake for my 318 RR...what next? [Re: MoparforLife] #886598
12/24/10 01:36 PM
12/24/10 01:36 PM
at least a good soaking and rebuild kit
move the carb and lets have a look at the intake
is it a spredbore intake?
is that holley a spredbore carb?
what are the list #s on the airhorn/front driverside?
if not a spredbore did it have a square to spredbore adaptor?
Re: got a 340 intake for my 318 RR...what next? [Re: scratchnfotraction] #886599
12/24/10 01:39 PM
12/24/10 01:39 PM
thats a nice 340 aircleaner
need to put that recpt and cover back on the box..thats troble waiting to happen
Re: got a 340 intake for my 318 RR...what next? [Re: scratchnfotraction] #886600
12/24/10 01:40 PM
12/24/10 01:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That is a speadbore Holley.. Mechanical secondaries = 4 mpg... Find a Thermoquad or a Mopar OE Quadrajet..
Re: got a 340 intake for my 318 RR...what next? [Re: 1_WILD_RT] #886601
12/24/10 02:15 PM
12/24/10 02:15 PM
Upper Midwest
Upper Midwest
You sure that that carb hasn't been through a fire. Maybe it is the picture but it looks to have been real hot at one time. Not good in my opinion.
Re: got a 340 intake for my 318 RR...what next? [Re: DaytonaTurbo] #886602
12/24/10 09:01 PM
12/24/10 09:01 PM
Pittsburgh, PA
Pittsburgh, PA
If you can swing an intake change, can you swing a little more for a cam change? The summit k6901 cam/lifter kit is only 110 bucks and I'm sure someone on here can suggest a set of valve springs. Add in a set of aftermarket headsers and you'll really wake that 318 up a lot more than just doing the intake.
i'd love to do that down the road, but wouldnt i have to change out the 904 tranny and 8.25 rear to handle the extra power? how far can i go?
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886603
12/24/10 09:48 PM
12/24/10 09:48 PM
no you dont have to change traz or rear axle
they will take a little HP upgrade
run them till they break then swap to bigger stuff
comp 901-16 springs are good for most cams that are a mild hydro cam,they are a single with damper,drop on with heads on engine,use stock valve seals and retainers
I steped mine up to a small roller cam with the 901s and run the 904 tranz with a high stall loc-up verter
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886604
12/24/10 09:56 PM
12/24/10 09:56 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You're not making that much power for it to be an issue. Also one thing you should really look into is what rear end gear ratio you have. 2bbl 318's tended to come with granny rear end gear ratios. Gears like that make for nice highway cruising but will make your car an absoloute DOG in the acceleration department.
I have run this cam on two different 318's with stock springs with no problems up to 5500 rpm. My 76 Feather Duster with this cam, a 72 340 TQ and duel exhaust was a screamer! The 4-speed and 3.55 gears helped too!
That's very interesting. If the stock springs will do it to 5500, assuming they're in good shape, that sounds like a good bet. Stock 318 heads are going to be done by 5500 anyway.
Re: got a 340 intake for my 318 RR...what next? [Re: DaytonaTurbo] #886605
12/24/10 10:04 PM
12/24/10 10:04 PM
Pittsburgh, PA
Pittsburgh, PA
ya know, i have no idea what gears are on the car, but i dont think they are the granny gears. its got decent pull from a dead stop even with its whopping 190 hp!
what other gears did they put in the 318s?
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886606
12/24/10 10:12 PM
12/24/10 10:12 PM
2.76,2.94,3.21,3.23.3.55,3.91 depends on what was orderd when new
most have a 2.76 open diff
3.55 are good for the street
3.91 are better but can get old on the highway
pull the rear cover and change the oil,probly needs it anyways..while its draining turn it to see the yr and gear ratio stamped on the ring gear
few bucks for 2 bottles of gear oil,that info is cheap and will be needed down the road with upgrades...also will know if its open or a sg unit
a short dur cam with high lift works great in a teen for street duty..gears multiply the torque and HP so the lower the better for launching it from stand still
Re: got a 340 intake for my 318 RR...what next? [Re: scratchnfotraction] #886607
12/24/10 10:22 PM
12/24/10 10:22 PM
Manitoba, Canada
Manitoba, Canada
Jack the back end up and count how many times the driveshaft turns for one complete revolution of the rear tires. If you have a suregrip you'll need to jack up both rear tires, if an open rear diff only jack up one tire. Take a marker and mark your driveshaft and tire when you start to rotate it so you can keep track.
Re: got a 340 intake for my 318 RR...what next? [Re: scratchnfotraction] #886608
12/24/10 10:30 PM
12/24/10 10:30 PM
Pittsburgh, PA
Pittsburgh, PA
too bad my dad doesn't remember...he's the original owner! i always get on him for getting the "base" model...he sold a 1970 340 duster for a 318 road runner! i've attached a pic in case you were interested.
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886609
12/24/10 10:54 PM
12/24/10 10:54 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Even with the 318, its probably a 3.21 since its a road runner, thats what one of my brothers 74 came with. Unless you can hook up with slicks, you will never hurt that 8 1/4 rear. I've done the bone stock 318 then cast intake 4 bbl with sq bore eddy carb/adaptor swap with headers and its makes for a quick reving, plenty of street power and great sounding combo on a budget. Nice looking car
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: got a 340 intake for my 318 RR...what next? [Re: bigdaddywiz] #886610
12/25/10 12:25 AM
12/25/10 12:25 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Page 2 of 3 1 2 3
