Charger Turn signal problems
#886517
12/23/10 02:16 PM
12/23/10 02:16 PM
Posts: 322 San Diego, CA, United States
Texas_Charger
I've got a '71 Charger S/E, non-tilt steering wheel that I just got back on the road. However, the turn signals on all four corners went out yesterday and I'm trying to figure out what went wrong. -Turn Signals dont work front or rear. Fender indicators or dash indicators dont work either. No ticking noise is heard from turn signal as well. -Turn signal switch is firm and disengages properly. -Brake lights do work. -Hazard lights do work. -tail lights do work then lights are on. -No blown fuses either. I purchased a turn signal switch repair kit, but I suspect the culprit is in the wiring. Any helpful advice that y'all may have would be greatly apreciated. Thanks!
1971 Dodge Charger SE 470/727/3.91 Suregrip 2016 Dodge Challenger Hellcat, 6-speed 1980 Pontiac Trans Am, Y84, WS6 2002 Ram 2500 Cummins/6-speed/2WD/QC 1971 Ford F-350 Ranger
Re: Charger Turn signal problems
[Re: bobs66440]
#886520
12/23/10 02:58 PM
12/23/10 02:58 PM
Texas_Charger
Thanks guys!
I just ran a circuit tester for the pigtail coming from the turn signal switch on the steering collumn. Everything shows power except the light green and tan wires for the left and right turn signals, so I'm assuming that the switch is the problem?
I really apreciate the help.
[Re: bobs66440]
#886522
12/23/10 03:09 PM
12/23/10 03:09 PM
Texas_Charger
The flasher is in line after the pigtail connection that I tested and got no power. That would lead me to believe the problem is the switch, correct?
[Re: stumpy]
#886525
12/23/10 03:59 PM
12/23/10 03:59 PM
Posts: 996 Queens, New York
Harley
Queens, New York
Flasher is before the switch and should have power. Why not just swap the flashers around and see what happens. I'll bet the turn signals work.
[Re: Yancy Derringer]
#886527
12/23/10 04:22 PM
12/23/10 04:22 PM
Texas_Charger
I tried two new flashers and neitehr of them worked. Any more ideas? Thanks!
[Re: stumpy]
#886529
12/23/10 07:43 PM
12/23/10 07:43 PM
Texas_Charger
I changed both of the flashers to make certain.
For some reason that I haven't figured out yet, there is no power at the flasher right now.
So far I have changed flashers, changed turn signal switches, and fuses without any luck.
[Re: Texas_Charger]
#886531
12/24/10 02:25 AM
12/24/10 02:25 AM
Posts: 377 Riverside, California
ghostrider
Is the power wire to the radio connector still connected like factory? Power goes in to radio and a second wire comes out of same place to go to flasher. Don't remember if that flasher is turn or 4 way though. Lots of people cut the connector off to put in aftermarket radio and don't reconnect that wire for the flasher.
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums.
Former Mopars include
69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
[Re: ghostrider]
#886533
12/24/10 12:38 PM
12/24/10 12:38 PM
Texas_Charger
This is exactly the mistake that I made. I assumed the black wire was the ground for the radio, but it turns out that it was the hot wire providing power to the flasher. Once I got power to that wire all was good. Again, thanks for all the help, I sure learned alot on this one.
[Re: Texas_Charger]
#886534
12/24/10 11:50 PM
12/24/10 11:50 PM
ghostrider
I learned this one while working on a 71 Sebring I used to have. Had to wait to get a wire diagram before I could figure it out.
