Re: 318 timing sprocket marks
[Re: jsswope67]
#886229
05/09/12 10:11 PM
05/09/12 10:11 PM
RapidRobert
put a light on it & time it at 10-15BTDC initial
[Re: jsswope67]
#886231
05/09/12 10:38 PM
05/09/12 10:38 PM
RapidRobert
Something dont sound right that it'll die with any less than 18 (If I read you right)
[Re: jsswope67]
#886233
05/09/12 11:49 PM
05/09/12 11:49 PM
Posts: 4,848 Memphis
HemiRick
Memphis
After you put it back together did you move any of the wires on the cap to make it run? if so that's why you can't see the line on the damper.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: jsswope67]
#886235
05/10/12 12:10 AM
05/10/12 12:10 AM
HemiRick
Memphis
For the line to be in the right place, so does #1 plug wire on the distributor need to be in the right place. Most likely you wires are rotated 180 from where there supposed to be on the cap and the distributor is also 180 out.
[Re: RapidRobert]
#886238
05/10/12 10:39 AM
05/10/12 10:39 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
Before giving advice like this a question needs to be asked ...
What distributor are you running and what changes to it have you made ?
If it is just a stock points or electronic and you have made no changes your first problem is you have way too much intial advance. Stock mopars distributor have 30 - 32 degrees of mechanical advance in them , with almost 20 degrees intial your mechanical is up to 50 degrees , no wonder it's pinging and running like bleep
[Re: jsswope67]
#886244
05/10/12 02:30 PM
05/10/12 02:30 PM
JohnRR
It's an out of the box electronic dist, new cap never changed any settings in the dist.
How old is it ?
You more than likely have too much total advance , that is why it's pinging.
