Page 2 of 3 1 2 3
Re: 318 timing sprocket marks [Re: jsswope67] #886229
05/09/12 09:11 PM
05/09/12 09:11 PM
put a light on it & time it at 10-15BTDC initial
Re: 318 timing sprocket marks [Re: RapidRobert] #886230
05/09/12 09:34 PM
05/09/12 09:34 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
Last I checked it was around 18 BTDC, any less it shut off..but I will check again with light.
Re: 318 timing sprocket marks [Re: jsswope67] #886231
05/09/12 09:38 PM
05/09/12 09:38 PM
Something dont sound right that it'll die with any less than 18 (If I read you right)
Re: 318 timing sprocket marks [Re: RapidRobert] #886232
05/09/12 09:43 PM
05/09/12 09:43 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
When I turned it more counter clockwise, yes it will bog out and not start, 18 was correct, never can see my solid dampener line either
Re: 318 timing sprocket marks [Re: jsswope67] #886233
05/09/12 10:49 PM
05/09/12 10:49 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
After you put it back together did you move any of the wires on the cap to make it run? if so that's why you can't see the line on the damper.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 318 timing sprocket marks [Re: HemiRick] #886234
05/09/12 11:02 PM
05/09/12 11:02 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
Yes, moved them a ton of times, didn't know the wire placement would show the line.
#1 wire is now on the tower that is marked 1 with a clockwise arrow. -Thanks any suggestions?
Re: 318 timing sprocket marks [Re: jsswope67] #886235
05/09/12 11:10 PM
05/09/12 11:10 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
For the line to be in the right place, so does #1 plug wire on the distributor need to be in the right place. Most likely you wires are rotated 180 from where there supposed to be on the cap and the distributor is also 180 out.
Take care,
Rick
Re: 318 timing sprocket marks [Re: HemiRick] #886236
05/09/12 11:48 PM
05/09/12 11:48 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
Sequence is 1-8-4-3-6-5-7-2
Just as a thought wires install clockwise? Correct? Small Block
I have the wires installed in sequence clockwise, but starting #1 wire on #1 dist tower that has a CC pointing arrow near the one, before the clip facing front of engine.
CC for Big Block?
Re: 318 timing sprocket marks [Re: HemiRick] #886237
05/10/12 12:17 AM
05/10/12 12:17 AM
PA
jsswope67 Offline
jsswope67  Offline
PA
Actually I think #1 wire now may be on the tower that is between the 2 that are marked "1" and that have the corresponding directions arrows.
Re: 318 timing sprocket marks [Re: RapidRobert] #886238
05/10/12 09:39 AM
05/10/12 09:39 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Before giving advice like this a question needs to be asked ...
What distributor are you running and what changes to it have you made ?
If it is just a stock points or electronic and you have made no changes your first problem is you have way too much intial advance. Stock mopars distributor have 30 - 32 degrees of mechanical advance in them , with almost 20 degrees intial your mechanical is up to 50 degrees , no wonder it's pinging and running like bleep
Re: 318 timing sprocket marks [Re: jsswope67] #886239
05/10/12 11:14 AM
05/10/12 11:14 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
CC for Big Block?
small block clockwise
Big block counter clockwise..
Tony
70 AARCuda Vitamin C
Re: 318 timing sprocket marks [Re: JohnRR] #886240
05/10/12 01:15 PM
05/10/12 01:15 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
It's an out of the box electronic dist, new cap never changed any settings in the dist.
Re: 318 timing sprocket marks [Re: 70AARcuda] #886241
05/10/12 01:18 PM
05/10/12 01:18 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
I can try again on the CW tower with the #1 cast mark on the cap, seems I did try that before, numerous times and it did not start. Or slowed the crankshaft down to a drag. I think now that #1 wire is on the CC #1 tower then 8-4-3-6-5-7-2 wired clockwise.
Re: 318 timing sprocket marks [Re: jsswope67] #886242
05/10/12 01:24 PM
05/10/12 01:24 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
How about putting the wires back to where it would run, then clipping timing light onto the wire that goes directly to the drivers side front cyl. (#1).
Re: 318 timing sprocket marks [Re: buildanother] #886243
05/10/12 01:29 PM
05/10/12 01:29 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
It runs now, will start now, will idle now, just heats up after a few miles, pings, shuts off or pings, loses power shuts off. Timing light now would show me around 18degrees, turing the dist either way slightly will shut it off. Any better than that , where would the wiring go? To the #1? CW tower?
Re: 318 timing sprocket marks [Re: jsswope67] #886244
05/10/12 01:30 PM
05/10/12 01:30 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
How old is it ?
You more than likely have too much total advance , that is why it's pinging.
Re: 318 timing sprocket marks [Re: JohnRR] #886245
05/10/12 01:31 PM
05/10/12 01:31 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
Year and 1/2 old, total advance? What's the setting?
Re: 318 timing sprocket marks [Re: JohnRR] #886246
05/10/12 01:39 PM
05/10/12 01:39 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
Going to put a light on it now and seeing where it stands again, will report back later. Thanks.
Re: 318 timing sprocket marks [Re: JohnRR] #886247
05/10/12 02:02 PM
05/10/12 02:02 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
Ok, #1 wire is on the tower just before the front clip going clockwise and the zero mark on the timing cover is showing 15BTDC with a timing light. Started up fine, it's a little cooler outside today about 56 degrees, idles, even backed it up a few feet. I know if I try and drive it, it will ping lose power and bog down.
Re: 318 timing sprocket marks [Re: JohnRR] #886248
05/10/12 02:11 PM
05/10/12 02:11 PM
PA
jsswope67 Offline
jsswope67  Offline
PA
Could it be the carb is running too too lean??
Page 2 of 3 1 2 3
