Page 1 of 3 1 2 3
Can I add spacers between frame and K member? #884738
12/20/10 10:40 PM
12/20/10 10:40 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
I need about 1/4" more space between my air cleaner and the underside of the hood. If I add a 1/4" spacer between the frame and K member will it mess up the steering geometry? Is there anything I'm not considering that would make this a dumb move? Will it put too much stress on the transmission mount or the torsion bars? I know it will need to be aligned. Maybe need to adjust fan shroud? Does the steering sector have enough play?
Please be gentle...
Thanks in advance all:)
BigBlock 74 Swinger
Re: Can I add spacers between frame and K member? [Re: bb74swngr] #884739
12/20/10 10:48 PM
12/20/10 10:48 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
If all you need is 1/4", then you should be able to do it with no ill effects. Try it. Put the 1/4" spacers in with no other changes and see how you like it. If there are issues that you don't care for, just remove them.
You can put spacers above the K with just a floor jack and jack stands in less than an hour. Just don't let the K go down any more than necessary to get the spacers in. Do one side a time.
Master, again and still
Re: Can I add spacers between frame and K member? [Re: DaveRS23] #884740
12/20/10 10:55 PM
12/20/10 10:55 PM
Missouri
mopar addict
mopar addict
Missouri
Good point Dave...I could just give it a try and take them out if something goes awry.
BigBlock 74 Swinger
Re: Can I add spacers between frame and K member? [Re: bb74swngr] #884741
12/21/10 12:55 AM
12/21/10 12:55 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Uhhhhh....
This sorta sounds like buying a hat that doesnt fit then going to get your head shrunk.
I'm all for cutting, fabricating and modifying things, but this is what locates the engine, steering and over half of the load of the transmission. I'd half to defer to the adage: What would the factory do: Ma Mopar would have tooled up for a different air cleaner base.
I did this very thing, and it worked out nicely. My Charger has a 493 with an Edelbrock Performer RPM intake. I liked the MP cast aluminum air cleaner, so I ordered one from Summit. It sat 3/4" to tall to clear my hood. I took my MP unit to a guy that is good with a TIG welder, along with a dropped base from another air cleaner assembly, and had him meld the two. It cost me $85, but it fits, looks right and all is right with the world.
Re: Can I add spacers between frame and K member? [Re: Kern Dog] #884742
12/21/10 02:37 AM
12/21/10 02:37 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Didn't the 68 hemi a-bodies do this?
NS1AAR
Re: Can I add spacers between frame and K member? [Re: ns1aar] #884743
12/21/10 03:18 AM
12/21/10 03:18 AM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
This has been a problem for guys running shakers on E-bodys also. Remember; if you lower the engine, you "may" also have to lower the transmmission mount, you "May" have to lower the radiator so the fan doesn't hit the shrowd?...So I wouldn't use a spacer either, I would cut your air cleaner base. But that is my opinion...
Re: Can I add spacers between frame and K member? [Re: GLR] #884744
12/21/10 11:55 AM
12/21/10 11:55 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
dont forget its also going to change your pinion angle
Re: Can I add spacers between frame and K member? [Re: bonefish] #884745
12/21/10 12:13 PM
12/21/10 12:13 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
The Hemi darts had em. However, I'd wonder if that 1/4 inch of static clearance is going to be enough when you bang that first shift.
I agree that it seems like the wrong end to shave some clearance in.
In order, redesign the filter, trim the top of the intake, add the spacers, then fab new motor mounts for additional clearance.
Re: Can I add spacers between frame and K member? [Re: RodStRace] #884746
12/21/10 01:26 PM
12/21/10 01:26 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Cut the intake top.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Can I add spacers between frame and K member? [Re: BradD] #884747
12/21/10 01:28 PM
12/21/10 01:28 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Depending on air cleaner style, get a shorter filter as in the case of the unsilenced air cleaner.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Can I add spacers between frame and K member? [Re: bb74swngr] #884748
12/21/10 01:30 PM
12/21/10 01:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Any implications for the torsion bars by spacing the k-member down?
Re: Can I add spacers between frame and K member? [Re: BradH] #884749
12/21/10 02:00 PM
12/21/10 02:00 PM
texas
magnum440 Offline
magnum440  Offline
texas
we put spacers on 71 hemi clone because of comversion motor mounts for shaker scoop to fit properly.....front end went together with no problems..when i aligned it came right into specs ...
Re: Can I add spacers between frame and K member? [Re: magnum440] #884750
12/21/10 02:59 PM
12/21/10 02:59 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I took in as many options as I could when I was swapping from a 4 bbl to a Dual Quad. I needed a 1/4" as well for clearance. I went ahead and got an aftermarket replica of a Dual Quad base from Steve (Paint It Black) and modified it to fit under my hood...69 Charger..no scoop and I have the sound deadener on the underside as well. I milled down two aluminum sleeves and set them under the drop base on top of both carbs, bought a K&N Oval Air Filter because it was slightly shorter than the FRAM type. It fits.
I dunno about messing with geometry, angles, and loads just for 1/4" I think you would run into some issue with your torsion bars, they are already under a great deal of shear tension. Then your steering linkage might bind somewhere.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Can I add spacers between frame and K member? [Re: Pyper70] #884751
12/21/10 04:18 PM
12/21/10 04:18 PM
Missouri
mopar addict
mopar addict
Missouri
Wow, thanks everyone. This has been a good learning experience with all of your input. I have modified the air cleaner as much as possible...there is no more room to cheat under the hood without milling parts. The 440 is setting as low as it can in the K member with Schumacher mounts. I have the Eddy dual quad CH-28 and everything fit fine until I added the NOS plates. I am using it the way it is right now but I can see rub marks on the bottom of the scoopless fiberglass hood. I am taking everyone's input seriously, so thanks again.
Russ:)
BigBlock 74 Swinger
Re: Can I add spacers between frame and K member? [Re: bb74swngr] #884752
12/21/10 05:52 PM
12/21/10 05:52 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Hows that CH28 working for ya?
Re: Can I add spacers between frame and K member? [Re: Pyper70] #884753
12/21/10 06:52 PM
12/21/10 06:52 PM
Missouri
mopar addict
mopar addict
Missouri
Love the CH-28, how about you? It has been great in every way. Folks at the car shows love it. It would be quicker with a single four but the wow factor is so much more fun.
Russ:)
BigBlock 74 Swinger
Re: Can I add spacers between frame and K member? [Re: bb74swngr] #884754
12/21/10 06:58 PM
12/21/10 06:58 PM
Missouri
mopar addict
mopar addict
Missouri
Pyper70 your setup looks awesome. Mine is not so fancy...kinda low keyed. Try to keep it ordinary looking...
BigBlock 74 Swinger
Re: Can I add spacers between frame and K member? [Re: bb74swngr] #884755
12/21/10 06:59 PM
12/21/10 06:59 PM
Missouri
mopar addict
mopar addict
Missouri
One more...
BigBlock 74 Swinger
Re: Can I add spacers between frame and K member? [Re: bb74swngr] #884756
12/21/10 07:33 PM
12/21/10 07:33 PM
BDW Online content
BDW  Online Content
Russ:)
What about a lower profile air filter and modifying the top of the air cleaner. Looks like it could come down some?
Re: Can I add spacers between frame and K member? [Re: BDW] #884757
12/21/10 07:45 PM
12/21/10 07:45 PM
Missouri
mopar addict
mopar addict
Missouri
Hi cnxt. I sure tried hard to find a slimmer air cleaner. This is the shortest Mopar piece and shortest filter I could find. Believe me I physically went through a ton of filters. I cut the bottom out of this one and lowered it to the top of the carbs with just enough room for the accelerator pumps to function properly. The throttle linkage just barely clears the base. I have been racking my brain for some way to get another 1/4". The car looks completely stock on the outside and it kills me to cut anything.
BigBlock 74 Swinger
Page 1 of 3 1 2 3
