Re: Can I add spacers between frame and K member?
[Re: bb74swngr]
#884758
12/21/10 07:50 PM
12/21/10 07:50 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
bb74...Are you sure you are sucking in enough air through a single snorkel? Maybe a dual snorkel would get you some better flow? Photobucket wont load up so here is the before shot before I cut it up to fit in my engine bay...Luckily no major slicing...just relocating the carb holes on the base. I guess if my 1/2" phenolic spacers fit then your 1/4" NOS should fit...My heights are pretty good as far as the hood is concerned
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#884759
12/21/10 07:58 PM
12/21/10 07:58 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Pyper, that setup looks sooooo good! The single snorkel is just for looks, the whole back of the air cleaner is open with a heavy screen. I hope it is enough and hasn't seemed to be starving for air. You can see it on the pic with the lid off. You are building a big cube engine?
BigBlock 74 Swinger
[Re: Stanton]
#884761
12/21/10 08:22 PM
12/21/10 08:22 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Stanton, that is a really big concern for me. I had the same thought about the torsion bars. There is a big contact area where they go into the crossmember and no wriggle room. Good question. Yes, a 7" scoop would work...does anyone make a 1/4" scoop? Just kidding:)
BigBlock 74 Swinger
[Re: bb74swngr]
#884762
12/21/10 08:26 PM
12/21/10 08:26 PM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
I say yes on dropping the front K member 1/4 inch I have done it with NO problems, All of the steering drops, so nothing there to get messed up The column still lines up, T Bars no problem The only thing that it does change is the ball joint angles a little. Would be a great place to use the tall disc spindles then
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#884763
12/21/10 08:36 PM
12/21/10 08:36 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Thank you Tom, that gives me some hope!
BigBlock 74 Swinger
[Re: Pyper70]
#884765
12/21/10 08:49 PM
12/21/10 08:49 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Thanks for the input Pyper...505 will be a handful of fun! Good luck on the build. I have decided to give it a try, like has been suggested you and others...I can always pull the spacers out.
BigBlock 74 Swinger
[Re: bb74swngr]
#884766
12/21/10 09:00 PM
12/21/10 09:00 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
I promise to do another thread/post after I have installed the spacers and tried it out for a while. I will report on the good, bad, or even ugly experience. It is in storage for the winter...live in the midwest. Over the winter I will be changing from a 6AL to a 6AL Plus, 3:23 to 3:91, Sirius radio, and K member SPACERS!
BigBlock 74 Swinger
[Re: moparts]
#884772
12/21/10 09:24 PM
12/21/10 09:24 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
And the tall spindles are 5/8" taller... I've seen 3/4" on quite a few cars... No problems.... Those torsion bars have quite a bit of movement in the anchors & even if they didn't last I heard they are spring steel.... Springs are designed to flex....
[Re: bb74swngr]
#884775
12/21/10 09:45 PM
12/21/10 09:45 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
They are the factory F/J/M body spindles... (Aspens/Miradas/StRegis Etc)
