how to ID my transmission #883585
12/19/10 01:05 AM
12/19/10 01:05 AM
Jefferson, OR
P
plumridiculous Offline OP
P
Jefferson, OR
A couple of weeks ago I picked up a 84 rampage that could be a direct connection rampage. But some thing don't ad up, like tire size listed on the door and a few other things. So the 5 speed makes noise running out of gear and the old owner said it would lock up at times shifting into 3rd. I was wondering how to determine witch trany is in is truck. from what I found on line it would be a 465 or the 525 if it is a direct connection rampage.
Thanks George..
Re: how to ID my transmission [Re: plumridiculous] #883586
12/19/10 01:47 AM
12/19/10 01:47 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Can't help with the trans ID, but more pics of the Pacer would be nice.
Is there a tag under one of the bolt heads holding the end plate of the transaxle in place?
Re: how to ID my transmission [Re: In_The_Pink] #883587
12/19/10 02:41 AM
12/19/10 02:41 AM
Jefferson, OR
P
P
Jefferson, OR
I'll look for the tag in the morning thanks
Here's one pic
Re: how to ID my transmission [Re: plumridiculous] #883588
12/19/10 12:33 PM
12/19/10 12:33 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Is the sequence # 263???.?
"Long Live Mopars"
Re: how to ID my transmission [Re: Furyman] #883589
12/19/10 03:18 PM
12/19/10 03:18 PM
Jefferson, OR
P
P
Jefferson, OR
The vin and fender tag last 6 digits are 357415.
I did find some numbers on the under side of trans where the half shafts attach, it is (4295481) and then (cavity 3) also (05111 * 84)
Do these mean anything?
Re: how to ID my transmission [Re: plumridiculous] #883590
12/19/10 03:26 PM
12/19/10 03:26 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
The ID tag is on the diff cover down by the dogbone mount. Take some brake cleaner and rags with you. They are usually all mucked over. My guess is you are going to have a 465. I you need one and can't find locally, I have both a 465 and 525 sittin out in the shop.
Re: how to ID my transmission [Re: tmef] #883591
12/19/10 07:33 PM
12/19/10 07:33 PM
Jefferson, OR
P
P
Jefferson, OR
I wouldn't have ever looked there, thanks. It is a A525
I'll see if I can find one around here but don't be surprised if I send you a message. I removed the cover on the end of the trans and found a broken sync ring.
thanks george
Re: how to ID my transmission [Re: plumridiculous] #883592
12/19/10 08:51 PM
12/19/10 08:51 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Don't forget to try www.car-part.com I've had good luck finding local stuff with them.
Re: how to ID my transmission [Re: In_The_Pink] #883593
12/22/10 01:38 AM
12/22/10 01:38 AM
Jefferson, OR
P
P
Jefferson, OR
I am having no trouble finding used transmissions in salvage yards the only problem is they don't record what it is just what it came out of. So they don't know if it is a 525 or 465. Some do record the final drive ratio in the 260 to 280 range. mine has a 387 gear ratio so I not sure wath the final would be.
George.
