Big block Dart #883575
12/19/10 12:12 AM
12/19/10 12:12 AM
Howell, Michigan
Hemidavey Offline OP
Howell, Michigan
What size tires came on a 68 big block Dart?
Re: Big block Dart [Re: Hemidavey] #883576
12/19/10 12:38 AM
12/19/10 12:38 AM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
My broadcast sheet has the numbers 3 9 in the tires block. Maybe someone can chime that has a break down on the code numbers.LS23H8B235XXX
Re: Big block Dart [Re: Hemidavey] #883577
12/19/10 11:20 AM
12/19/10 11:20 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
F70-14 comes to mind but I have no way of proving if I'm correct.
Re: Big block Dart [Re: Hemidavey] #883578
12/19/10 12:27 PM
12/19/10 12:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
E70-14.
Re: Big block Dart [Re: JohnRR] #883579
12/19/10 01:20 PM
12/19/10 01:20 PM
Howell, Michigan
Howell, Michigan
I want to find a similar sized 14 tire in a radial cause I'm gonna drive the wheels off this Hemi Dart! The original tires look great but are poor on the road.
Thanks for all your input!
Re: Big block Dart [Re: Hemidavey] #883580
12/20/10 11:57 AM
12/20/10 11:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can fit an F70 sized tire in it , that's what I run on my 69 GTS
Re: Big block Dart [Re: JohnRR] #883581
12/20/10 12:10 PM
12/20/10 12:10 PM
Commando1 Offline
Commando1  Offline
AH! That's why F70 came to mind. I ran them regularly on my 67.
Re: Big block Dart [Re: Hemidavey] #883582
12/20/10 03:44 PM
12/20/10 03:44 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
With all due respect...........
ANY of those little 14" tires are not going to hook like a larger 15" D.O.T. sticky tire.
I'd look into an aftermarket 15X7" steel wheel and a J-60 or 235/60R-15 to upgrade.
Re: Big block Dart [Re: Dean_Kuzluzski] #883583
12/20/10 06:03 PM
12/20/10 06:03 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
I've got 14's on the front of my Scamp, and all the way around on my old Nissan p/u- and some of the 14" sizes are getting hard to find...
Re: Big block Dart [Re: donbarnes] #883584
12/23/10 07:24 PM
12/23/10 07:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I owned a 68 383 4 speed convertible. Its O.E. tires were Goodyear Polyglas E70-14. Soon after my purchase in 1974 I installed E60-14/H60-14 with Ansen Sprints 14x6 and 14x7. I would run 15" in todays world. 255-60x15 rear 205-70x15 front.
Doug
