Page 3 of 3 1 2 3
Re: Engine Masters: SB hemi wins with 700HP! [Re: Get-X] #883195
12/20/10 09:32 PM
12/20/10 09:32 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
And its still a HEMI ( technically )
Meaning, it says so in the ads?
Meaning it has the same chamber shape as the old Hemi, and not the wedge chamber like a Hemi99.
Actually, the chambers are not shaped like the old hemi. They are not hemispherical at all.
TR Waters
Re: Engine Masters: SB hemi wins with 700HP! [Re: Dragula] #883196
12/20/10 09:56 PM
12/20/10 09:56 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Also it means that it is a small block, not a big block like all the original HEMI's were.
Sorry, but the originals WERE small blocks!
I understand that. I was not trying to argue with anyone.
I was making more of a joke than anything.
I was refering to the 426 HEMI. Sorry about that.
Re: Engine Masters: SB hemi wins with 700HP! [Re: Dragula] #883197
12/20/10 10:36 PM
12/20/10 10:36 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
well a hemi on race gas in a 3000lb car,ah i give up..
Re: Engine Masters: SB hemi wins with 700HP! [Re: TrWaters] #883198
12/20/10 11:00 PM
12/20/10 11:00 PM
nc
moeflo Offline
moeflo  Offline
nc
If you look at how the individual scallops around each valve deshroud with lift you'll find it's done to mimic the intake diffusion patterns that a 426 does so well. You don't throw away what works. Making the chamber a full bowl shape would add a lot of volume while disturbing the intake flow. This is due to the valve angles. If it were a full bowl shape the chamber would be too flat. If this was good we'd all have 409 chevys.
The new hemis are how a narrow valve angle hemi is done if you want it to run like one. Everybody can call it what they want. As far as what matters, it's a hemi.
Re: Engine Masters: SB hemi wins with 700HP! [Re: onebaddakota] #883199
12/21/10 02:39 AM
12/21/10 02:39 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Did anyone else catch that?
It's really a testament about the importance of port efficiency and how much the old wedge heads suck. This is nothing new, the old heads were just designed to be cheap to manufacture, performance was secondary, if not even farther down the list. One peek down the intake port of a wedge head shows what a torture chamber for moving gasses looks like. Tilting the valve toward the corresponding manifold naturally makes for a shorter port and takes away some of the opportunity for complex geometry. Now to piss off some people: how much does the 5.7/6.1 intake valve position and angle differ from the 318 poly? (see picture)
Re: Engine Masters: SB hemi wins with 700HP! [Re: @#$%&*!] #883200
12/21/10 09:58 AM
12/21/10 09:58 AM
nc
moeflo Offline
moeflo  Offline
nc
The poly is very close to the 99 in it's valve layout. The valve locations/angles in the old 318's were never a performance problem. Intakes with angles favoring the ports, no side cant and a 0° exhaust angle. (the 99 began with a 2° exhaust angle, both no side cant)
The poly ports were designed around getting it to fit engine bays. (same thing that hurt the early 426 hemi's exhaust ) Like Drag Stripper said, performance was way, way down the list on nearly all OE hi-production engines. Also, he's dead on about the paths the intake ports must take in a wedge. It's why a hemi will out flow a wedge with the same cross-section. When setting a flow curve, you will give up more flow on one end in order to optimize the flow on the other. much more with a wedge than a hemi.
On polys and B,RB for that matter,1/2 inch longer valves and corresponding taller castings would have helped tremendously from the git-go. (They should have cut that 1/2 inch from the deck instead...) But packaging was the first priority.
The hew hemis ports and valves are centered and the angles very close, (the same?). In that regard, it's more hemish than a 426. There were some who complained that the 426 wasn't a true hemi because the intake and exhaust angles were different. In retrospect, that's a weak argument. I suspect the same will eventually be true regarding the new hemis.
Somewhere along the way we made up this idea that all 2V engines fell into either wedge or hemi. It just ain't so.
Re: Engine Masters: SB hemi wins with 700HP! [Re: moeflo] #883201
12/22/10 12:23 PM
12/22/10 12:23 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's nice to see the Gen 3 catching on a little bit
Re: Engine Masters: SB hemi wins with 700HP! [Re: ZIPPY] #883202
12/22/10 12:27 PM
12/22/10 12:27 PM
detroit area
moderncylinder Offline
detroit area
are you guys sure it had 5.7 heads on it?? i guess i havent seen "new" 5.7 heads, but the drag pack intake is meant to fit 6.1 heads,,, there are no 5.7 heads on any packages they offer. id think the intake is for 6.1 heads,,, so they used 6.1 heads
Re: Engine Masters: SB hemi wins with 700HP! [Re: moderncylinder] #883203
12/22/10 12:36 PM
12/22/10 12:36 PM
NY usa
540challenger Offline
NY usa
The newer 5.7L heads have larger ports then the older version. They are very close to the 6.1L heads and the intake for can swap over.
Re: Engine Masters: SB hemi wins with 700HP! [Re: 540challenger] #883204
12/22/10 01:29 PM
12/22/10 01:29 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
This is true since 2009 when VCT hit, AKA "5.7 Eagle"
Rich H.
Esse Quam Videri
Re: Engine Masters: SB hemi wins with 700HP! [Re: moderncylinder] #883205
12/22/10 07:25 PM
12/22/10 07:25 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
You really didn't know that ? Wow.
The port window on both the I & E is very close to the 6.1 head.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Engine Masters: SB hemi wins with 700HP! [Re: AlexP] #883206
12/22/10 08:21 PM
12/22/10 08:21 PM
detroit area
detroit area
no,, i havent seen a new 5.7 head,, ive done about 15 sets of 6.1 heads in the last year,,, no 5.7 heads.....
the drag pack 5.7 hemi has the 6.1 head on it
Re: Engine Masters: SB hemi wins with 700HP! [Re: moderncylinder] #883207
12/22/10 09:56 PM
12/22/10 09:56 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I'd take a look at it. It's the best compromise between the two. A tight combustion chamber, smaller than 6.1 intake ports with the 6.1 exhaust port.
Makes big power, even in stock form on a 5.7.
Re: Engine Masters: SB hemi wins with 700HP! [Re: ZIPPY] #883208
01/31/11 07:58 PM
01/31/11 07:58 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Tell me you have a Chrysler part# for the new eagles heads. Matt
Re: Engine Masters: SB hemi wins with 700HP! [Re: MattW] #883209
01/31/11 10:15 PM
01/31/11 10:15 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
emarine01,
The rod length listed in the PHR detail article is 6.125. With a 4.250 stroke thats a 1.44 rod ratio. Kinda kills the long rods are needed to make power thing
Re: Engine Masters: SB hemi wins with 700HP! [Re: ProSport] #883210
01/31/11 10:37 PM
01/31/11 10:37 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Steff I just looked up all the available superchargers and they are pretty pricey anyways.
Seriously considering selling my 500" Indy headed low deck and starting a 6.1 project, Rick gave me the idea and Steff's photos awhile back were making me drool some.
Hey Prosport, I have seen enough of your posts to convince to get a gen3 hemi. We traded a couple PM's and I say sell it and put a 6.1 or 5.7 hemi in. I will help in anyway I can.
I have 5.7 hemi with a tko in a 69 fast back cuda. It will have a centrifugal supercharger on it.
So besides pushrod length, what needs to be done to be the eagle 5.7 heads on the old 5.7 hemi. I know compression jumps up. Any links to the head swap on this.
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Engine Masters: SB hemi wins with 700HP! [Re: wldtm] #883211
01/31/11 11:04 PM
01/31/11 11:04 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I'd still LOVE to do this someday but in this economy I'd have to give my motor away. I would need to get good money for my motor, then find a smokin deal on a new Hemi so I could use the extra money to beef it up. And then my Ultrabell equipped 727 wouldn't work as it's a big block tranny. Heck I'd be better off just building an old 426 Hemi so I can utilize my tranny, water pump, motor plate etc. But the 6.1 sure would be a fun project, I'm anxious to see your Cuda all done.
Re: Engine Masters: SB hemi wins with 700HP! [Re: fbs63] #883212
02/01/11 12:58 AM
02/01/11 12:58 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
emarine01,
They are not revving over 7K or so and have to put up good numbers even lower in the rev range than most motors, long rods help high RPM power and short rods help low RPM power. Proven many time over on dynos all over the world. Not a huge difference and probably less then 15 peak hp on most motors but it is still there. There are other places in most motors to find more of a difference for less dollars but in an all out motor they will find a R/S ratio that best fits there needs and in this case the heads give them awesome power up top and they need more down low so a short rod will help them where as if they were building a drag only motor where it stays at higher RPM all the time then they would probably have tried to find a little longer rod.
Re: Engine Masters: SB hemi wins with 700HP! [Re: HotRodDave] #883213
02/04/11 12:25 PM
02/04/11 12:25 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
emarine01,
I thought I would give this a bump with all the talk of G3.
Page 3 of 3 1 2 3
