Re: What Hp do you think my 493 indy head motor makes?
[Re: dennismopar73]
#882063
12/16/10 08:36 PM
12/16/10 08:36 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
With a roller and decently flowing SR's I would think you could be in the 630 range pretty easy If the heads are only 'touched up" I'd say right at 590-600. But it doesn't really take much to get an SR well over a comparably prepped E-head and 10.88 is decent enough and would work well with that roller, you've got a lot of the right parts there to make over 600. It's a swag without the headflow numbers but I'm thinking if you have a 2.19" intake you could be flowing about 310 at .550 (they'll go about 285 OOTB IIRC). A 252 intake lobe seems small seat to seat but your .200-up durations should be better than a ~265 @.050 solid flat tappet which would certainly support a 600 hp motor like I would build it anyway. Beautiful car by the way. I know yellow is a tough color to photograph accurately.... I'm sure it's eye-popping in person!!
[Re: cjs69mope]
#882065
12/16/10 11:35 PM
12/16/10 11:35 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Nice car. Why such low compression? Do you burn a lot of fuel every month or something?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#882066
12/17/10 01:32 AM
12/17/10 01:32 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
Thanks for all the kind words it has been a project of mine for the past 4 years . No i have not had it on dodge charger.com I don't know how to post a picture i have tried many times a year or so ago and my file pictures are to big i guess so i gave up not that good with computers . The car was built by my own two hands paint body and mechanical done in the home garage , its not a jackson car just a nice weakend street /strip car. Oh yea i just wanted to burn pump gas for easy sake .so that is why i went light on compression . But the cranking compression of the engine is 200-205 psi and remember it has .o40 quench with zero deck (very crisp response )!
It has many good mods to it , where to begin Well it was an original 318 car with auto on the column . I always wanted 440 car so i built one . I always believed a hot rod has to be stick shift so i converted it to a 1970 hemi 4sp pistol grip with the best looking mopar setup on to ever come from a auto manufacture 70 pistol grip console shifter !18 spline trans Dual friction clutch , Chrome molly drive shaft , Billet steel yoke ,4:10 with Detroit locker and moser axles with rear wildwood setup on the rear brakes . The front brakes are the viper gen 1 kit from AR. The front end has been stiffened ,by welding and gusseting up the k member ,. Firm feel 2 power steering box with firm feel tubular upper control arms &boxed lowers , with firm feel sway bar. I run a steel left side motor mount to hold it down with a 5/8 bolt. The car has 17 inch wheels front and rear front tires are 215/60R17 and rears are 345/45r17 M/H drag radials . Full 3inch TTI exhaust with x pipe and 50 series delta flow flow masters only because i like flow master sound ! Thats about it she is really fast on the street and handles real well ! I plan on getting to the track this spring to see what she will do but not that worried i think i can get her into the 11s if i drive good . I will try to post more pics if i can figur out how to resize them . Cj.
1969 Dodge Charger
1969 Dodge Superbee
