Re: What Hp do you think my 493 indy head motor makes? [Re: dennismopar73] #882063
12/16/10 08:36 PM
12/16/10 08:36 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
With a roller and decently flowing SR's I would think you could be in the 630 range pretty easy If the heads are only 'touched up" I'd say right at 590-600. But it doesn't really take much to get an SR well over a comparably prepped E-head and 10.88 is decent enough and would work well with that roller, you've got a lot of the right parts there to make over 600. It's a swag without the headflow numbers but I'm thinking if you have a 2.19" intake you could be flowing about 310 at .550 (they'll go about 285 OOTB IIRC). A 252 intake lobe seems small seat to seat but your .200-up durations should be better than a ~265 @.050 solid flat tappet which would certainly support a 600 hp motor like I would build it anyway.
Beautiful car by the way. I know yellow is a tough color to photograph accurately.... I'm sure it's eye-popping in person!!
WIZE
In Car:
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882064
12/16/10 09:17 PM
12/16/10 09:17 PM
Upland, California
Spode Offline
Spode  Offline
Upland, California
Nice car plus I like the color combo
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882065
12/16/10 11:35 PM
12/16/10 11:35 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Nice car. Why such low compression? Do you burn a lot of fuel every month or something?
Re: What Hp do you think my 493 indy head motor makes? [Re: jbc426] #882066
12/17/10 01:32 AM
12/17/10 01:32 AM
IL . usa
cjs69mope Offline OP
IL . usa
Thanks for all the kind words it has been a project of mine for the past 4 years .
No i have not had it on dodge charger.com
I don't know how to post a picture i have tried many times a year or so ago and my file pictures are to big i guess so i gave up not that good with computers .
The car was built by my own two hands paint body and mechanical done in the home garage , its not a jackson car just a nice weakend street /strip car. Oh yea i just wanted to burn pump gas for easy sake .so that is why i went light on compression .
But the cranking compression of the engine is 200-205 psi and remember it has .o40 quench with zero deck (very crisp response )!
It has many good mods to it , where to begin
Well it was an original 318 car with auto on the column .
I always wanted 440 car so i built one .
I always believed a hot rod has to be stick shift
so i converted it to a 1970 hemi 4sp pistol grip with the best looking mopar setup on to ever come from a auto manufacture 70 pistol grip console shifter !18 spline trans
Dual friction clutch , Chrome molly drive shaft ,
Billet steel yoke ,4:10 with Detroit locker and moser axles with rear wildwood setup on the rear brakes .
The front brakes are the viper gen 1 kit from AR.
The front end has been stiffened ,by welding and gusseting up the k member ,.
Firm feel 2 power steering box with firm feel tubular upper control arms &boxed lowers , with firm feel sway bar.
I run a steel left side motor mount to hold it down with a 5/8 bolt.
The car has 17 inch wheels front and rear
front tires are 215/60R17 and rears are 345/45r17 M/H drag radials .
Full 3inch TTI exhaust with x pipe and 50 series delta flow flow masters only because i like flow master sound ! Thats about it she is really fast on the street and handles real well !
I plan on getting to the track this spring to see what she will do but not that worried i think i can get her into the 11s if i drive good .
I will try to post more pics if i can figur out how to resize them . Cj.
1969 Dodge Charger 1969 Dodge Superbee
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882067
12/17/10 02:01 AM
12/17/10 02:01 AM
IL . usa
IL . usa
another picture
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882068
12/17/10 02:03 AM
12/17/10 02:03 AM
IL . usa
IL . usa
interior shot
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882069
12/17/10 02:06 AM
12/17/10 02:06 AM
IL . usa
IL . usa
butt shot
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882070
12/17/10 03:27 AM
12/17/10 03:27 AM
What kind of power do you guys think i am making ?
Here is the setup
493 rb block zero deck
ross pistons compression is 10.88 to 1 static
compression is 8.65 to 1 dynamic
Heads: Indy sr with bowl port and intake ports matched .And competition valve job .
Cam :comp solid Roller .252 .260 dur @.050
.630 gross lift
lobe separation 108
cam installed at 104c/l
Intake: M1 single plane ported
Carb; MightyDemon 850 anular
malory hyfire VI digital ignition 36 deg total
tti 2 to 2 1/8 step headers
carb is tuned to 12.9 a/f ratio with lm2 meter at full throttle . on pump 93 octane gas
what kind of numbers do you think i could be putting down ?
Car is 69 charger with hemi 4spd and 4:10 gear approx weight 3800
600+ HP and close to 650 Ft. Lbs. at the flywheel easily Hooking it and keeping it hook will be the challenge
Re: What Hp do you think my 493 indy head motor makes? [Re: Cab_Burge] #882071
12/17/10 07:27 AM
12/17/10 07:27 AM
Q
Quicktree Offline
Quicktree  Offline
Q
beautiful car, great job
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882072
12/17/10 09:27 AM
12/17/10 09:27 AM
gregsdart Online content
gregsdart  Online Content
My second good car was a 69 charger, wanting another! Great job, looks Great!
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882073
12/17/10 12:51 PM
12/17/10 12:51 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
MAN!!!! i think i completly changed my mind about yellow
