Re: Installing single leafs and CalTracs on a late "B" [Re: mshred] #881422
12/17/10 06:04 PM
12/17/10 06:04 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
This is cool! Got any more pics of the car? what combo and what does it run if you dont mind sharing
Mild408,727, 9/14 diff w/4:10's. 11.72@115.38 to date.
http://s79.photobucket.com/albums/j160/jcailey/?action=view&current=1180pass.mp4
Fastest 300
Re: Installing single leafs and CalTracs on a late "B" [Re: Crizila] #881423
12/17/10 06:17 PM
12/17/10 06:17 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Sweet
Re: Installing single leafs and CalTracs on a late "B" [Re: mshred] #881424
12/19/10 08:48 AM
12/19/10 08:48 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Looks very good
Caltracks and ss spring boxes work well for some, others it dont.
22 pounds off each side going with the std f-body caltrack/mono setup vs the SS boxes and multi leafs..
Did you have to make any spring adjustments, as in slide the front or rear seg one way or another??
I run a inch shorter wheel base in the rear/ 1/2 in the front and had to move the mono-s back seg one inch back to sit properly in the rear spring sliders.
Cool your using the big mopar rear
Re: Installing single leafs and CalTracs on a late "B" [Re: quick77rt ] #881425
12/20/10 09:41 PM
12/20/10 09:41 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Looks very good
Used the stock front spring perches ( after I drilled them for the 5/8" bolts ) so my axle stayed in the same location. Both my stock multi-leaf springs and Calvert Mono springs had 22" front sections.
Fastest 300
