{{{ WHEELS - POWDERCOAT or PAINT...???? }}} #879700
12/14/10 10:21 AM
12/14/10 10:21 AM
Lehigh Acres, Florida
rickstershemi Offline OP
OK this is basically the color I am going with on the Valiant....should I paint the wheels to match (will get dog dish caps) or have them powdercoated black....?????? If I powercoat them should I order the rear raw & have them powdercoated with my stock fronts so the finish matches...or just order them already powdercoated....?????
Tires....raised white letter Firestone Wide-O-val polyglass.
Rickster
Re: {{{ WHEELS - POWDERCOAT or PAINT...???? }}} [Re: rickstershemi] #879701
12/14/10 09:34 PM
12/14/10 09:34 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
You can never go wrong with black wheels IMO. Shiny wheels would also look awesome. Dislike any painted color wheel on it.
Re: {{{ WHEELS - POWDERCOAT or PAINT...???? }}} [Re: ChrisJohnston669] #879702
12/14/10 09:39 PM
12/14/10 09:39 PM
Gig Harbor,WA
Commando66 Offline
Commando66  Offline
Gig Harbor,WA
If you're using dog dish caps, the would have originally body color. This is how I personally like it.
Re: {{{ WHEELS - POWDERCOAT or PAINT...???? }}} [Re: rickstershemi] #879703
12/14/10 10:34 PM
12/14/10 10:34 PM
southwest pa
bodyworks racing Offline
southwest pa
i would not powder coat anything imo you are much better off media blasting your wheels and using a good epoxy primer followed with a single stage urethane topcoat to many rust problems with powder coat
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: {{{ WHEELS - POWDERCOAT or PAINT...???? }}} [Re: bodyworks racing] #879704
12/14/10 10:54 PM
12/14/10 10:54 PM
Your probaly right...hmmm...I think I'll spray them with Ospho now since they have already been blasted then when the weather warms up I have some epoxy black primer I can paint them to see if I like the black look and always shoot them with the body color later....thanks, great idea
Rickster
Re: {{{ WHEELS - POWDERCOAT or PAINT...???? }}} [Re: rickstershemi] #879705
12/14/10 10:57 PM
12/14/10 10:57 PM
southwest pa
southwest pa
ospho is good stuff i use it on all my bare steel
Re: {{{ WHEELS - POWDERCOAT or PAINT...???? }}} [Re: rickstershemi] #879706
12/14/10 11:48 PM
12/14/10 11:48 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
