Page 1 of 3 1 2 3
Oil Consumption Culprit Found!!! #877720
12/11/10 08:56 PM
12/11/10 08:56 PM
Out in Left Field, NY
bobs66440 Offline OP
Well, as some of you know I've been chasing a 1qt. per 200 mile oil consumption issue and this is what I found when I pulled the intake (at the advice of some of you here). Oil everywhere...on both sides of the pan, a lot inside the intake runners and also the intake ports. Unfortunately much buildup on the intake valves too. There was only the valley pan with no gaskets used except silicone at the front and rear rails and looks like some crusty sealer on there.
This is a sample of what's in the intake ports...
Do you guys think that this could be responsible for that much oil usage? This is the last thing to try before going the rebuild route, which I hate to do because it runs so good...I don't want to open a can of worms (and my wallet).
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877721
12/11/10 08:59 PM
12/11/10 08:59 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
The oil buildup around the intakes is a BIG clue. It's either coming from the
valley leak
valve guides
or pcv
There's no other way to get oil into that part of the engine
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877722
12/11/10 09:02 PM
12/11/10 09:02 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Looks like.
If the intake gasket is leaking it can in deed suck up a lot of oil, but a leak like that will usually cause the motor to run very poorly. Pic number three looks really bad. Leaking at the top of the intake runner. Is that orange on the intake paint from another engine? Sealer?
Re: Oil Consumption Culprit Found? [Re: Yancy Derringer] #877723
12/11/10 09:03 PM
12/11/10 09:03 PM
I'm pretty sure it's not from the guides or seals because the guides seem tight and I put new seals in with no improvement at all despite the old ones being in real bad shape.
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877724
12/11/10 09:06 PM
12/11/10 09:06 PM
Kirkland, Washington
Pacnorthcuda Offline
1qt/200 miles is a Lot of oil to suck buy the pan but I suppose its possible. Others disagree but I prefer to use the composition gaskets on both sides of the valley pan. I even superglue them to the pan the day before install--very anal about it, I create wood plates to clamp both sides.
What ever you do dont use RTV around the intake runners--RTV is not gasoline resistant.
You may have more than one source of oil loss.
Re: Oil Consumption Culprit Found? [Re: bboogieart] #877725
12/11/10 09:06 PM
12/11/10 09:06 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Orange looks like sealer.
Re: Oil Consumption Culprit Found? [Re: bboogieart] #877726
12/11/10 09:06 PM
12/11/10 09:06 PM
Looks like.
It looks like orange paint, presumably from another engine because this one isn't orange. Though I suppose it could be sealer...
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877727
12/11/10 09:07 PM
12/11/10 09:07 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I was looking at intake gasket seal not valve guides.
Re: Oil Consumption Culprit Found? [Re: bboogieart] #877728
12/11/10 09:13 PM
12/11/10 09:13 PM
Yeah sorry, I was responding to Yancy Derringer's post.
Re: Oil Consumption Culprit Found? [Re: Pacnorthcuda] #877729
12/11/10 09:16 PM
12/11/10 09:16 PM
Do you mean these?
I was thinking of using these but heard that they raise the intake up too high to get the bolts started...though I haven't tried it yet.
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877730
12/11/10 09:26 PM
12/11/10 09:26 PM
Do you mean these?
Yep ! Absolutely. Mock it up first to see if fitment is an issue, I've had good luck with 4 different intakes on 2 different 440's, One with milled heads too.
Re: Oil Consumption Culprit Found? [Re: Pacnorthcuda] #877731
12/11/10 09:35 PM
12/11/10 09:35 PM
Do you mean these?
Would you use any sealer with the gaskets?
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877732
12/11/10 09:40 PM
12/11/10 09:40 PM
I use superglue to the pan so there is no chance of them "walking". I don't use anything against the intake or heads.
You could use something else to secure them to the pan, but make sure is gasoline resistant.
After I glue them I then trim any excess material that protrudes beyond the intake divider.
Re: Oil Consumption Culprit Found? [Re: Pacnorthcuda] #877733
12/11/10 09:44 PM
12/11/10 09:44 PM
Ok, thanks!
Re: Oil Consumption Culprit Found? [Re: Pacnorthcuda] #877734
12/11/10 09:45 PM
12/11/10 09:45 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
We sell paper gaskets for the pan, only .015 thick so they don't jack up the intake. Glue them to the pan and no air/oil leaks. Thinnest ones on the market, had them made to avoid the jack-up problem with everyone else's gaskets.
Re: Oil Consumption Culprit Found? [Re: topside] #877735
12/11/10 10:04 PM
12/11/10 10:04 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
It looks like orange paint, presumably from another engine because this one isn't orange.The blue motor is why I asked, I was thinking if the old paint was still on there it needs to be cleaned better and checked for flatness. Can paint be a problem? I think so. Sealer is no match for a good clean flat mating surface. Hope it is an easy fix.
Re: Oil Consumption Culprit Found? [Re: bboogieart] #877736
12/11/10 10:20 PM
12/11/10 10:20 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Check intake for straightness. W/o the heat riser blocked, it sends a ton of heat to it.
Re: Oil Consumption Culprit Found? [Re: SomeCarGuy] #877737
12/11/10 11:49 PM
12/11/10 11:49 PM
I will definitely do that. And I'm going to block the crossover too.
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877738
12/12/10 04:13 AM
12/12/10 04:13 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I had good luck with using no extra gaskets or sealer on the valley pan. I just shot both sides with several good coats of the permatex copper spray, did the rtv on the pan rails. Also had to use permatex thread sealer on the intake manifold bolts because a lot of oil was getting sucked up the threads.
Re: Oil Consumption Culprit Found? [Re: DaytonaTurbo] #877739
12/12/10 09:46 AM
12/12/10 09:46 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Looks like oil around the bolt holes.
Page 1 of 3 1 2 3
