Re: "Don't ask me how I know..."
[Re: Just Cameron]
#634
07/11/03 02:45 PM
07/11/03 02:45 PM
[Re: Just Cameron]
#635
07/11/03 02:49 PM
07/11/03 02:49 PM
If you don't put the stainless trim tabs in before putting the windshield in, you have to pull the windshield back out, then put the clips in and put the windshield back. You will probably ruen the gasket and need to buy another.
[Re: Just Cameron]
#638
07/11/03 02:55 PM
07/11/03 02:55 PM
Dumping antifreeze on a fire doesn't put it out but actually turns it into a raging inferno!
[Re: Just Cameron]
#642
07/11/03 03:04 PM
07/11/03 03:04 PM
Posts: 3,773 Candler, NC
Roughrdr
Candler, NC
A burping carb can give you a nice clean, but tender and smelly, shave and a haircut
Chains of habit - too light to be felt until they are too heavy to be broken
[Re: Roughrdr]
#643
07/11/03 03:05 PM
07/11/03 03:05 PM
Roughrdr
Candler, NC
LOng hair and carbs don't play well with each other
[Re: Roughrdr]
#646
07/11/03 03:08 PM
07/11/03 03:08 PM
Roughrdr
Candler, NC
When locking keys in trunk, It would be easy to go in thru the back seat if it wasn't for the metal plate mandated by NHRA to seperate fuel cell from passenger compartment
[Re: BSharp]
#651
07/11/03 05:01 PM
07/11/03 05:01 PM
Posts: 2,006 Yorktown VA
motorheadjohn
Ridin' Shotgun
Ridin' Shotgun
Yorktown VA
(1) If you're changing oil on your motorcycle and fail to replace the drain plug, the new synthetic oil is guaranteed to run out on your boot and make a hard-to-clean-up mess.
(2) Always check the operation of your automatic trans kickdown linkage, and verify there is no binding, with the engine off, before taking it on a test drive.
(3) If your gas pedal sticks on the floor due to a bound kickdown linkage, and you're going down a 2-lane road quickly approaching slower traffic, turn the key off. Do not turn it back to where it locks the steering wheel. Also, failure to immediately bump transmission into neutral may result in blown-out mufflers.
Don't ask me how I know.....
Chicks in the mirror are fatter than they appear
[Re: BSharp]
#652
07/11/03 05:08 PM
07/11/03 05:08 PM
Posts: 494 Sun City, AZ
MTTwister
super gas
super gas
Sun City, AZ
Brake Fluid makes a great anti-coagulant. External use only recommended.
Sold the Duster a few years ago...
