Re: Ishihara-Johnson Crank Scrapers
[Re: Max Weg]
#875337
12/09/10 02:47 AM
12/09/10 02:47 AM
Posts: 43,355 Bend,OR USA
Cab_Burge
I make my own crankshaft scrapers for B-RB and 426 Hemi out of soft aluminum sheets. I shoot for .030 to .060 clearances on steel rod motors and .075+ on aluminum rod motors ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Locomotion]
#875338
12/09/10 03:13 AM
12/09/10 03:13 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Actually I recently had my first teflon scraper sent to my engine builder. I've been running the regular ones. Never read the instructions for the teflon version, but from what I recall, they can be set pretty close and are suppose to be "self-clearancing".
I see they have your pic on their web site ... congrats ![](/ubbthreads/images/graemlins/wave.gif)
[Re: slantzilla]
#875343
12/09/10 11:08 PM
12/09/10 11:08 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I have a Johnson scraper in my Slant. I have never been able to get Kevin to provide any proof as to how much gain there is. Whenever I asked him he started quoting off the wall numbers for 4.6 Fords and such.
You wanted dyno results from a /6? ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Max Weg]
#875344
12/09/10 11:45 PM
12/09/10 11:45 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
You can use the scrapers with a windage tray..there are some very neat engineering on some one off scrapers that you wouldnt see commercially. Believe me, a lot of the stock eliminator guys use these succesfully, and Kevin has made some very trick scrapers with special additions and requirements.
You want .040 clearance on a standard steel scraper that does not use the Teflon. On the Teflon lined versions, you can run with an interference fit with the Teflon. yes it actually will self clearance to some degree.You aim for a "slight" drag.There are several methods to secure the scraper properly so it doesnt move, I have my methods, but the everday accepted practice is to lay a bead of silocone on the pan rail after doing your final ,mock up and check fit,mark it, then place the scraper in the bead of silicone. Let it set up.Smear silicone again on the surface of the scraper tht will be against the windage tray. Double check for fitment and any interference,then silicone your oil pan and install against windage tray.
Thats a pretty simple , quick explanation .If I get the time, I'll post a Teflon scraper pic later.
RIP Monte Smith
[Re: CompWedgeEngines]
#875346
12/10/10 01:26 AM
12/10/10 01:26 AM
Posts: 139 Canada
Max Weg
Canada
I have ordered one with the teflon option and will give it a try. I just was curious to see if anyone had done a Dyno session with and without. I intend on using dowel pins just like a typical crank scraper. Do you use the down stroke scraper? If so is the downstroke clearance the same?
Thanks Max Weg
[Re: VanishPt]
#875349
12/10/10 06:20 PM
12/10/10 06:20 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The Ishihara-Johnson scraper has a full pan rail.
[Re: VanishPt]
#875350
12/10/10 06:34 PM
12/10/10 06:34 PM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
It woulds seem that the oil pan would no longer lay flat on the rail if you install a piece of metal on just one side of the rail. What would keep the oil pan from leaking if it were not sitting flush all the way around?
It is bolted to the main caps and does not interfere with the pan rail unless my eyes are playing tricks on me. ![](/ubbthreads/images/graemlins/scope.gif)
[Re: VanishPt]
#875351
12/10/10 07:06 PM
12/10/10 07:06 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
![](http://sitebuilder.yola.com/restricted_view/site_design/8a4986c81daed352011dc18073f264c7/resources/Scraper%2030.JPG)
[Re: BSB67]
#875352
12/10/10 07:18 PM
12/10/10 07:18 PM
Posts: 2,521 Richmond Va, KeislerTKO 60...
VanishPt
DOH. ![](/ubbthreads/images/graemlins/shock.gif) that explains it. Thanks for the info and the picture. How would you get one of those made for a motor in the car. Call up a guy and say " I have a Callies 4.5" stroke crank on a Hemi. Please send me one."?
