Page 11 of 18 1 2 9 10 11 12 13 17 18
Re: Early '70s SS/DA Cuda [Re: nz383man] #874306
02/04/11 08:48 AM
02/04/11 08:48 AM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Frank Madden & Roger England at Columbus
Re: Early '70s SS/DA Cuda [Re: Frito] #874307
02/04/11 05:00 PM
02/04/11 05:00 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
I'm looking for advice on a period correct tach, any input on dates for this lot?
The info I have on this next one is "Sun Super Tach 10000 RPM Blue Line Model SST-801. Dated 11-2-68"
Did the Sun Super Tach II not come out until the very early '80s?
What about these?
Re: Early '70s SS/DA Cuda [Re: nz383man] #874308
02/04/11 05:29 PM
02/04/11 05:29 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
what brand & model of tach would be period correct for an early '70s SS/DA car?
Stewart Warner gauges were what most ran back then. They come up once in a while.
Re: Early '70s SS/DA Cuda [Re: JERICOGTX] #874309
02/04/11 05:51 PM
02/04/11 05:51 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
More like this one from a 1967 ad?
I'll look through my '69-'71 Hot Rod mags & see what ads I find, Cheers
Re: Early '70s SS/DA Cuda [Re: nz383man] #874310
02/04/11 06:01 PM
02/04/11 06:01 PM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Most of the RACE cars of this era were using the Jones/Motorola, Stahl or Moroso mechanical tach. These have a cable from the back of the tack into the dist. housing. Of course you had to have the dist. that was conpatable to the cable drive tach. The Sun Super tach that you are showing was the one to have for street cars but if you are going for the accurate race look, the mechanical cable drive one is the way to go.
Re: Early '70s SS/DA Cuda [Re: Frito] #874311
02/04/11 06:09 PM
02/04/11 06:09 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
OK, now thats opened things up a bit, I have never heard of some of those brands living my sheltered life in New Zealand so I'm very greatful for the info. I do have a couple of Accell tach drive distributors that I plan to build a 90 degree twin dizzy setup from so I may be able to run a mechanical cable drive from one of them, I love a challenge!
Re: Early '70s SS/DA Cuda [Re: nz383man] #874312
02/04/11 08:59 PM
02/04/11 08:59 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
You just want the tach for the correct period look,,right? I would say any of them would fit the criteria. As far as actually using a tach to shift with,,,I always remember a friend of mine's reply, who was also a low-buck bracket racer, when I asked him "why don't you have a tach in your car?"...He said....."If Butch Leal don't need one,, I %#@&^*% sure don't need one!"
P.S. I DO use one.. I believe the cable drive tach would be the best.
If you like drag racing, support your local track.
Re: Early '70s SS/DA Cuda [Re: CHAPPER] #874313
02/04/11 09:04 PM
02/04/11 09:04 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Re: Early '70s SS/DA Cuda [Re: CHAPPER] #874314
02/04/11 09:19 PM
02/04/11 09:19 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
So if I could track down any of these I'd be on the right track?
Jones Motrola MOROSO
MOROSO
Stahl
Re: Early '70s SS/DA Cuda [Re: HPMike] #874315
02/04/11 09:22 PM
02/04/11 09:22 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Hey Mike, what brand is the one in your photo?
Re: Early '70s SS/DA Cuda [Re: nz383man] #874316
02/04/11 09:32 PM
02/04/11 09:32 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
That one in the previous pic is a Jones...
These are the gauges that came right out of my 71 SS/DA Hemi Challenger. The finish on the tach is textured, like a "suede" finish. I can't say these are rare, but I never seen another one like it. It's pretty sweet. The S/W's are
MB
Re: Early '70s SS/DA Cuda [Re: HPMike] #874317
02/04/11 09:33 PM
02/04/11 09:33 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
side view
Re: Early '70s SS/DA Cuda [Re: HPMike] #874318
02/04/11 09:39 PM
02/04/11 09:39 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
My RoadRunner had that exact same tach in 20 years ago when we got it. Too bad it was broke shortly after removing it from the car.
Re: Early '70s SS/DA Cuda [Re: JERICOGTX] #874319
02/05/11 05:46 AM
02/05/11 05:46 AM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
StewartP had this photo.
Re: Early '70s SS/DA Cuda [Re: Frito] #874320
02/05/11 12:57 PM
02/05/11 12:57 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If your looking for accurate reading from a sun tach forget that, I think I had three back in the day before Accel and they would wander all over at high rpm's. But they looked sharp, still do.
Re: Early '70s SS/DA Cuda [Re: rowin4] #874321
02/05/11 01:15 PM
02/05/11 01:15 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Sox and Martin used Stewart Warner. The Chrysler race program had the SW 535AH tach listed in their catalog.
Nautilus Racing-
Re: Early '70s SS/DA Cuda [Re: Chris2581] #874322
02/05/11 01:19 PM
02/05/11 01:19 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Re: Early '70s SS/DA Cuda [Re: JERICOGTX] #874323
02/05/11 09:15 PM
02/05/11 09:15 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Cheers Guys, that's great info, I think I will hold out for a mechanical tach from either Stewart Warner or Stahl/MOROSO they are both great looking tachs, period correct & hopefully accurate!
I think using a mechanical tach will help give my car the serious drag car look I'm going for so even though it will be more difficult to go mechanical I think it will make it more authentic.
Re: Early '70s SS/DA Cuda [Re: nz383man] #874324
02/05/11 09:47 PM
02/05/11 09:47 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Plenty of the Stewart Warner 535AH's on Ebay and not expensive either.They are VERY reliable tachometers,I have 2 in 2 different cars and the one in the Road Runner was bought new in 1972.
Nautilus Racing-
Re: Early '70s SS/DA Cuda [Re: Chris2581] #874325
02/05/11 10:51 PM
02/05/11 10:51 PM
Connecticut
ASA1711 Offline
ASA1711  Offline
Connecticut
