Re: DON'T ASK ME HOW I KNOW
[Re: moparmanjames]
#871815
12/05/10 03:56 PM
12/05/10 03:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When backing out of your trailer and the car comes to a stop dont pull forward and try it faster this time... it MAY tear the collectors off your headers DONT ASK ME HOW T KNOW ![](/ubbthreads/images/graemlins/wave.gif)
[Re: mopars4ever]
#871820
12/05/10 07:39 PM
12/05/10 07:39 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
When coming back home for a race dont assume the road is a little rough, it could be the trailer tire shredding apart. dont ask me how I know..........as I pull into a steak and shake parking lot to eat. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: Mopar_racer_99]
#871821
12/05/10 07:56 PM
12/05/10 07:56 PM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
When you go to your favorite gas station and pull up to your favorite pump and proceed to put a full tankof gas in your cummins powered truck after a party. Drive it home and never batt an eye. Kinds makes some nice white smoke the next morning. Don't ask me how I know. Damon ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: mopardamo]
#871823
12/05/10 08:35 PM
12/05/10 08:35 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
You are running an index class and need to slow down a little more. All of your tricks are in a MSD 7531 box like huge timing retard in low gear only. Don't get happy and lower the shift point without first looking at the value you have in RPM drop to recognize high gear. Pulling 22 degrees in low gear slow you down a lot. Pull the normal 22 degrees in low go to high and the engine is not coming back to life. [Edited by Moparts - Family Friendly Site - Keep it clean]. 7,800 converter. 8,100 shift point. RPM drop to recognize high gear 400. Still pulling 22 degree in high gear. Instead of running 5.95 you just ran a 6.60.
[Re: Leon441]
#871825
12/05/10 08:39 PM
12/05/10 08:39 PM
Leon441
Lynchburg, VA
You are still running an index class with a MSD 7531 for your tricks. You first decide to run on the DOTS. You are testing and running dead on. Next day qualify under. OK just shift sooner. The car picks up a tenth. You just jumped off the rev limiter now that you are in high gear. 5.80 on a 6.00 you probably just lost the race.
[Re: Leon441]
#871827
12/05/10 08:41 PM
12/05/10 08:41 PM
Leon441
Lynchburg, VA
Still index racing MSD 7531 Yata Yata Yata. Still running the DOTS but scared to shift early. Pull a ton of timing in low gear. Car does not run hard enough to hit the DOTS but is way to fast. First round of ellimination. What to do What to do.
[Re: Leon441]
#871828
12/05/10 08:45 PM
12/05/10 08:45 PM
Leon441
Lynchburg, VA
Still running the index. Got all the MSD 7531 down pat. Running dead on 6.001, 6.003. Nothing can go wrong. Racing a combo race 6.00 agains 7.00. Mopar in the other lane running 7.0. Its the finals. Do the burnout stage car cuts off. [Edited by Moparts - Family Friendly Site - Keep it clean]. Fuel pump just took a dump.
Get home and realize the fuel pump fuse in the ARC panel is blown. Put another one in blows again. Start digging. The wire is pinched where it exits the panel.
When testing and the ARC panel opens up going down track. You are running 150 MPH 1/4 mile don't just reach up and close the panel and tighten the screw. It may have just pinched the wire later causing problems at the worse time.
[Re: Leon441]
#871829
12/05/10 09:49 PM
12/05/10 09:49 PM
After buying the wrong lights for the christmas tree and you have to go back to exchange them don't forget to bring your wallet, don't ask me how I know. ![](/ubbthreads/images/graemlins/flame.gif)
