Page 3 of 5 1 2 3 4 5
Re: DON'T ASK ME HOW I KNOW [Re: HEMIFRED] #871833
12/05/10 10:39 PM
12/05/10 10:39 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Don't put a live .22 cartrige in a wadd of silly putty and bounce it on the tile floor.
Not car related, but DON'T ASK ME HOW I KNOW
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: DON'T ASK ME HOW I KNOW [Re: sixpackgut] #871834
12/05/10 10:44 PM
12/05/10 10:44 PM
oregon
savoyracer Offline
savoyracer  Offline
oregon
dont put gas in a mt dew bottle
............I imagine it took awhile to get that taste out
Re: DON'T ASK ME HOW I KNOW [Re: HEMIFRED] #871835
12/05/10 11:26 PM
12/05/10 11:26 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
All Cars REQUIRE the oil filter to be in place before priming the engine.
DO NOT ASK ME HOW I KNOW
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: DON'T ASK ME HOW I KNOW [Re: fasteddie] #871836
12/06/10 01:32 AM
12/06/10 01:32 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
If you install a transmission temperature gauge into one of those aluminum blocks make sure the bulb from the gauge does not block the fluid's flow . If not your trans will read hot
home of the
Sox and Martin Hemi Duster
Re: DON'T ASK ME HOW I KNOW [Re: HEMIFRED] #871837
12/06/10 01:41 AM
12/06/10 01:41 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Don't park your truck on a hillside at camp and allow your buddy to shoot up the hillside with an SKS in the middle of the night. Makes a mess of the body, glass and wiring harness.
Don't ask me how I know!
Damon
Re: DON'T ASK ME HOW I KNOW [Re: topside] #871838
12/06/10 08:23 AM
12/06/10 08:23 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It's always a good idea to at least take a peek at the trailer ramps before backing the car off, especially if you've been distracted and only 1 ramp is down...
Don't ask me how I know...
I did that once! LOL!!
Re: DON'T ASK ME HOW I KNOW [Re: fasteddie] #871839
12/06/10 10:53 AM
12/06/10 10:53 AM
Löffingen, Germany
The_Mean_Machine Offline
Löffingen, Germany
...and the gauge for oil press concted
DAMHIK
Re: DON'T ASK ME HOW I KNOW [Re: Dodgem] #871840
12/06/10 10:57 AM
12/06/10 10:57 AM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline
If you think you have a lifter ticking at idle that gets worse with RPM before you replace all your lifters make sure you check your header gaskets for leaks....
DONT ASK ME HOW I KNOW!!!
Don
Street/Strip 73 Barracuda
Re: DON'T ASK ME HOW I KNOW [Re: The Cuda Guy] #871841
12/06/10 11:44 AM
12/06/10 11:44 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Always remember to put your hood pins in before making the mad dash for the racing fuel truck's last call...
Re: DON'T ASK ME HOW I KNOW [Re: moparmanjames] #871842
12/06/10 01:27 PM
12/06/10 01:27 PM
Az
Crizila Offline
Crizila  Offline
Az
When you are all done with that compression test, don't forget to remove the screw driver you jambed down the carb to hold the throttle blades open - before you fire it up. DON'T ASK ME HOW I KNOW!!!
Fastest 300
Re: DON'T ASK ME HOW I KNOW [Re: Crizila] #871843
12/06/10 03:00 PM
12/06/10 03:00 PM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
when working in a shop with a die hard chevy mechanic, watching him put the intake on with the paper towel still in the intake ports of the heads!!! all the while keeping a straight face untill he starts it!!!! ASK ME HOW I KNOW !!!
Re: DON'T ASK ME HOW I KNOW [Re: mopartoby] #871844
12/06/10 04:07 PM
12/06/10 04:07 PM
Mesa, Arizona
6pak2go Offline
6pak2go  Offline
Mesa, Arizona
When replacing an intake gasket on a small block six-pack, after cleaning the bottom of the intake sealing surfaces with a red shop towel, make sure the towel is not stuck to the bottom of the intake when you pick it up and place it back on the engine.
Robert R
Mesa, AZ
70 Challenger R/T 440-6 4-Sp Cruiser
67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
Re: DON'T ASK ME HOW I KNOW [Re: The Cuda Guy] #871845
12/06/10 05:19 PM
12/06/10 05:19 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Don
I know...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: DON'T ASK ME HOW I KNOW [Re: 6pak2go] #871846
12/06/10 05:51 PM
12/06/10 05:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Just gotta say, I never let red shop rags get anywhere close to my motors. Always lintfree paper towels. Red rags will cost you eventually if you use them around motors.
Re: DON'T ASK ME HOW I KNOW [Re: Challenger 1] #871847
12/06/10 07:29 PM
12/06/10 07:29 PM
Sacramento, Ca
sanger440 Offline
sanger440  Offline
Sacramento, Ca
When transporting your SB Mopar engine from your old house to your new house on an engine stand, make sure it is not a cheap ass harbor freight engine stand. Even if it is strapped down tightly in a very nice enclosed trailer a couple of ill timed bumps across some RR tracks on the way to the new house will fatigue the chinese crap steel arms on the engine stand and cause some real damage.
Re: DON'T ASK ME HOW I KNOW [Re: sanger440] #871848
12/06/10 09:08 PM
12/06/10 09:08 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Don't think you cant brake a breaker bar just cause its 3/4 drive Don't ask me how I know
Re: DON'T ASK ME HOW I KNOW [Re: fasteddie] #871849
12/07/10 11:25 PM
12/07/10 11:25 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Dang Eddie, I thought I was the only one to pull that bone headed move. At least I'm in good company!
And it makes one mell of a hess to clean up when you're already in a hurry. DAMHIK!
Brian Dunnigan
Re: DON'T ASK ME HOW I KNOW [Re: HEMIFRED] #871850
12/07/10 11:49 PM
12/07/10 11:49 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Being nagged while assembling a motor, then find out that you left out a wrist pin button when you let go of the TB and have a set of 40's in it.
8.30's @3400 lbs
Re: DON'T ASK ME HOW I KNOW [Re: Mike Swann] #871851
12/08/10 07:39 AM
12/08/10 07:39 AM
gregsdart Offline
gregsdart  Offline
If you feel the trailer "bump" you when you hit the brakes, then jerk when you take off, you probably forgot to tie one end of the race car down,,,,,,,,, DAHIK!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: DON'T ASK ME HOW I KNOW [Re: gregsdart] #871852
12/08/10 09:56 AM
12/08/10 09:56 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Make sure the activation switch for the nitrous system is turned off before you pump the gas to start the car..... Ask me how I know.....
Randy
