EGR valve question
#871761
12/05/10 02:48 AM
12/05/10 02:48 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Ok this is an odd one. I put a stock 4-v intake on my '75 truck. I'm going to run an Edelbrock 600 CFM carb with no spacer. It cleared on a 400 with an EGR blockoff plate but wouldnt clear the EGR valve on the smallblock.
Can I lop the top off the valve and have a makeshift blockoff plate? Or, will I simply need to find a factory blockoff plate?
I'm in need of getting this thing on the road because its my only mode of transportation right now.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
Re: EGR valve question
[Re: mopars rule]
#871764
12/05/10 04:26 PM
12/05/10 04:26 PM
Posts: 606 Montana
Yancy Derringer
Montana
I would just remove it and find a piece of flat steel, drill a couple holes in it and make a gasket for it and put rvt on it and bolt down.
THIS
[Re: Yancy Derringer]
#871765
12/05/10 11:27 PM
12/05/10 11:27 PM
Posts: 15,487 Florida
scratchnfotraction
yes,knocj the top part off and leave the base bolted up done a bunch like that i take a cut off tool to them,only takes a second
[Re: scratchnfotraction]
#871766
12/06/10 02:27 AM
12/06/10 02:27 AM
MoPar Jamie
Sarcoxie, MO, USA
Thats what I did, pried the top off and took bolt cutters to the shaft. Ugly now but it works and the truck runs much better. Eventually I'll do a plate if I make the motor nice but not now.
- MoPar Jamie
