Big block timing fluctuations with solid roller cam ?
#870425
12/03/10 06:28 PM
12/03/10 06:28 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Can somebody educate me on how by putting a collar at the bottom of the distributor shaft helps stop this? I see two different types out there one is $6.00 and one is $80.00 . I do think that my timing does walk a few degrees at idle but seams to smooth out if you hold the r.p.m.s up with the throttle. Has anybody seen a difference by using the distributor collar and what type works best for the money ? Thanks Moparts .
1969 Dodge Charger
1969 Dodge Superbee
Re: Big block timing fluctuations with solid roller cam ?
[Re: cjs69mope]
#870427
12/03/10 06:46 PM
12/03/10 06:46 PM
Posts: 3,903 Oregon
hooziewhatsit
I think it helped on my 318; timing seemed more steady afterwards The collar keeps the distributor gear from walking up towards the distributor. Since it's a gear, if it comes up, it rotates a little and changes the angle to the distributor, which changes the timing (slightly). The collar is attached to the distributor, which is bolted to the block, so it keeps the gear at its lowest point and prevents it from walking back up. I just used a Home Depot $5 1/2 collar.
[Re: hooziewhatsit]
#870428
12/03/10 06:51 PM
12/03/10 06:51 PM
RapidRobert
Use the cheap one, slide it on the end, snug the setscrew, set dist in to locate the collar further up the shaft, take it out & tighten/loctite it securely. reinstall the dist. If you timing chain is good your timing will be steady. EDIT Also peen the end of the shaft (on each side) to widen it so it fits tight in the intermediate shaft recess as there's also play there that causes scatter
[Re: Dcuda69]
#870429
12/03/10 06:52 PM
12/03/10 06:52 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
OK but how does it work what does it fix ? is the cam moving or is the distributor moving side to side or what ? Some say that you need this. Not sure i want to spend the money though . web page
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#870430
12/03/10 07:59 PM
12/03/10 07:59 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Cam is moving and the gear is moving, what is happening is the gear is walking up and down and the collar stops this. Dvoraks is a fancy setup to do with the hardware store part , made in china , does.
[Re: Yancy Derringer]
#870432
12/04/10 02:01 AM
12/04/10 02:01 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
I see the light ! thank you for clearing this up for me i am going to pay more close of attention to this in all my cars from now on it makes sense . i think the cars will run a little better too . Thanks again guys.
1969 Dodge Charger
1969 Dodge Superbee
