Page 2 of 3 1 2 3
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: 70B5Cuda] #869658
12/17/10 03:57 PM
12/17/10 03:57 PM
Newton, KS
70B5Cuda Offline
70B5Cuda  Offline
Newton, KS
In bare metal
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: 70B5Cuda] #869659
12/17/10 03:58 PM
12/17/10 03:58 PM
Newton, KS
70B5Cuda Offline
70B5Cuda  Offline
Newton, KS
In DP90 that same night
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: 70B5Cuda] #869660
12/17/10 09:28 PM
12/17/10 09:28 PM
washington
AB&E Offline
AB&E  Offline
washington
talk to your paint store; most will tell you to stay away from soda because of adhession problems & the paint companies will not guarantee paint. every thing I have read & was told tells me to stay away so thats why I bought a media blaster & used walnuts awesome job no residue left in cracks to haunt you later like paint falling off. after your $10,000.00 paint job {to each their own do the homework}
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: BigDaddy440] #869661
12/17/10 10:03 PM
12/17/10 10:03 PM
iowa
copchaser Offline
copchaser  Offline
iowa
I own a restoration/body shop. 90% of the cars we do we have media blasted. The guy I use uses soda and crushed glass. We have had ZERO problems from soda. You have to prep and wash the metal, after using soda or expect problems. I've never been involved with having a body dipped. As far as paint companys not standing behind there paint due to the use of soda, I've never heard that. I've had paint reps at the shop and I've asked them point blank about soda, they have no problem with it. Has any one ever truely had a paint problem? 99% of the time it's traced back to either poor prep work, or incorrect flash times.
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: copchaser] #869662
12/18/10 12:15 AM
12/18/10 12:15 AM
washington
AB&E Offline
AB&E  Offline
washington
my paint store told me that on the can or the fine print disclamer maybe not all brands I use ppg dupont??? also Ive read of problems of seepage out of seams or not de activating good enough causing problems down the road but I am not a pro just an average joe just google it on internet read for yourself like I said I was sold on soda & almost purchased a blaster I did but used walnut it worked okay for in the driveway use just my opinion
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: AB&E] #869663
12/18/10 12:45 AM
12/18/10 12:45 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Anyone ever use this stuff Clean Blast.??
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: 19cuda73] #869664
12/18/10 12:55 AM
12/18/10 12:55 AM
washington
AB&E Offline
AB&E  Offline
washington
what is it looks expensive walnuts cheap leave under tree when done
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: AB&E] #869665
12/18/10 02:26 AM
12/18/10 02:26 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Kleen blast, it a black sand like .060 grit material I use it in my blast cabinet. When I bought the cabinet it came with 500 lbs of the stuff. It says its non-silica material.
1972 Corvette
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: 19cuda73] #869666
12/18/10 09:07 AM
12/18/10 09:07 AM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
I work for PPG and have never heard of paint companies not standing behind the paint because someone used soda. Where did that come from?
Paint companies dont stand behind people who dont properly prepare the substrates for adhesion. Alot of bumpkins do not adequates prepare for the adhesion of coatings including primers. You can dip a car and have it completely stripped and yet if you do not have the car nuetralized correctly (and the same holds with soda) you will have issues early on. When your spraying the vehicle and the particles of sand, soda or whatever comes out of crevices and gets on the surface you will a have issues a plenty. Problem is (from our end) is that everyone wants to make the coatings mfg the "whipping boy". Everybody thinks paint is paint and their a painter. 95% of the time the issue is in the prep of the surfaces (substrate) of the cars. Everything from the environments such as humidity, correct preparation of the paint product in mixture, familiarity with your spray equipment and body prep come into play. The overwhelming majority of mistakes are made in these areas, but the overwhelming majority will complain its the "paints fault". A common issue is the lack of prep "after" the soda, black beauty, or chemical compounds have been applied to strip the car. Our PPG automotive division consists of dealer owned stores, and of course each runs their center as they see fit (within reason), but PPG does not trash you out and say "nope we wont warrantee our product because you soda blasted your car."
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: gomangoRTSE] #869667
12/18/10 02:11 PM
12/18/10 02:11 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i have talked to the local PPG and Dupont reps and neither have a problem with soda. Being a blaster and doing soda as my main media i hear this every day about the evils of soda. i am to the point were i am switching to walnuts because i am tired of explaining and defending soda to customers who "read on the internet"
I talked to a customer on thursday who wants his 58 bug blasted, i sugested walnuts and he said no, he wanted soda, he told me he read on the internet that walnuts leave a oil residue behind and paint falls off.
dont believe everything you read on the internet
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: chrisf] #869668
12/18/10 02:54 PM
12/18/10 02:54 PM
washington
AB&E Offline
AB&E  Offline
washington
okay tear me up like I said just what ive heard & just my opinion this is a 50-50 either way I think just depends on what ya want to use. every one has a opinion does not make it right or wrong!! just an opinion
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: AB&E] #869669
12/18/10 03:15 PM
12/18/10 03:15 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
AB+E what do you base your opinion on? is it first hand experience or something you have read? just curious.
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: chrisf] #869670
12/18/10 08:31 PM
12/18/10 08:31 PM
Pittsburgh, PA
Deuces-Wild Offline
Deuces-Wild  Offline
Pittsburgh, PA
What are folks using to blast away the factory paint off of rallye wheels? (something safe where you don't affect the stampings).
I am not sure if it is powdercoated but its hard and chemicals have not worked. Will soda remove powdercoat?
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: Deuces-Wild] #869671
12/18/10 10:08 PM
12/18/10 10:08 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
I did six wheels last week in my blast cabinet with the Kleen blast abrasive .060 grit.
1972 Corvette
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: 19cuda73] #869672
12/18/10 11:34 PM
12/18/10 11:34 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Never heard of that brand. I'm sure that is coal slage. Nothing wrong with that, same stuff I use.
All the the coal slage I have used has been "non silca"
That's why my supplier quit selling silica sand and started selling coal slage. AKA Black Beauty, Black Lightining, Black this and Black that...lol
I'm thinking your .060 grit is about the same as 30/60 here that I use, which is perfect for blasting wheels.
I have done about 20 or so at a time, never hurt the stampings, not even close. I still have some in the the garage all painted. Maybe some pictures... if I go out and take em.
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: Challenger 1] #869673
12/18/10 11:57 PM
12/18/10 11:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
I'm pretty sure I blasted these with some 20/40 coal slage, which is courser than 30/60.
As you can see, it didn't hurt the numbers, But sure does get rid of rust which means pitted metal. These old 14' wheels are all blasted and painted with the right argent silver, in lacquer!
To bad there 14s...lol
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: Challenger 1] #869674
12/19/10 12:36 AM
12/19/10 12:36 AM
Cincinnati, Ohio
Cincinnati, Ohio
I just realized that I had a rear taillight housing for 74 challenger sitting here blasted with 20/40 coal slage. I't in my full time heated garage and is not rusting yet. I don't touch it with bare hands.It'll get blasted again after it's welded back on the car.
It's sitting next to a deck lid that I did with plastic, real fast because I was running low on plastic and I knew I wasn't gonna use it on my last car.
It had 2 red paint jobs on top of that body work. Someone had already sanded off the original color and laid down some red oxide with holes sanded in it!!
I bet the first red paint didn't turn out so well, that's why there were 2. It never looked that good when I got it either. Except the biggee, no rust, no where. It was a dream car to restore.
The deck lid needs a DA taken to it to make it bare. The plastic took pimer and 2 paint jobs off of it though real fast.
Whoever said plastic is slow, is wrong. It cut's just as well or better than coal slage. Just shoot it at a lower PSI.
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: chrisf] #869675
12/21/10 07:01 PM
12/21/10 07:01 PM
washington
AB&E Offline
AB&E  Offline
washington
well I stripped my 69 bee with walnuts myself & like I said I was sold on soda but changed my mind after reading bad articles about it. have I used soda NO THANK YOU I restore my own cars except for paint&body work & I do agree its in the prep you have to get it off & out of all seams. so my main thing is for pros maybe okay because if my paint bubbles at seems I can let you redo it for novice users I would beware itS all in the prep baby. just my opinion like yours take it or leave it DONT CARE
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: AB&E] #869676
12/21/10 07:19 PM
12/21/10 07:19 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i wasnt hacking you opinion, I just wanted to know if it was first hand experience or something you had read. If you go looking your going to find a simular arguement with walnuts leaving oil behind.
I blast with both soda and walnuts now so it really doesnt matter to me. whatever the customer wants
Re: Lets talk about Media Blasting Types (Soda vs Others) [Re: chrisf] #869677
12/21/10 09:01 PM
12/21/10 09:01 PM
washington
AB&E Offline
AB&E  Offline
washington
OKAY HAVE FUN
Page 2 of 3 1 2 3
