question for anyone running dual quads #86918
07/10/08 07:49 PM
07/10/08 07:49 PM
ohio
dodgedart416 Offline OP
ohio
Do you idle with both carbs or just one? If just one which one? Thanks
Re: question for anyone running dual quads [Re: dodgedart416] #86919
07/10/08 08:07 PM
07/10/08 08:07 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
both. They should both be open the same amount (syncronized). Even 6 packs need to have the end carbs' throttle opening and mix set.
Re: question for anyone running dual quads [Re: RodStRace] #86920
07/11/08 07:53 AM
07/11/08 07:53 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think my Street Hemi idled on the primaries of the rear carb. Everthing else was progressive. I dont remember idle screws on the front carb. Has been a long time ago, though.
Re: question for anyone running dual quads [Re: RodStRace] #86921
07/11/08 09:13 AM
07/11/08 09:13 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Pretty sure the outboard carbs don't have idle circuits in them.
Dual quads USUALLY idle on one carb and I don't think it matters which one. If you have a big cam and can't get it to idle without adjusting it past the transition into the main circuit, you could then set it up to idle on BOTH carbs.
Kevin
Re: question for anyone running dual quads [Re: Twostick] #86922
07/11/08 09:20 AM
07/11/08 09:20 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Re: question for anyone running dual quads [Re: dodgedart416] #86923
07/11/08 09:42 AM
07/11/08 09:42 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
What intake are you using ?
What carbs are you using ?
Re: question for anyone running dual quads [Re: dodgedart416] #86924
07/11/08 10:05 AM
07/11/08 10:05 AM
Canada
CrAzYMoPaRGuY Offline
Canada
BOTH carbs.
CrAzYMoPaRGuY
Re: question for anyone running dual quads [Re: RodStRace] #86925
07/11/08 01:15 PM
07/11/08 01:15 PM
Not necessarily.
It depends on how you set up your linkage. What you are talking about is not the way the factory did it. For both hemi and six pack they were set up progressively. Meaning that on the hemi the front two barrels of the rear carb first then the rear two barrels of the rear carb, then the front two barrels of the front carb and finally the rear two barrels of the front carb.
Aftermarket some set them up to pull the front and rear carb in at the same time, but that was typically race only.
A factory six pack was set up to run off of the center two barrels first.
Re: question for anyone running dual quads [Re: dodgedart416] #86926
07/11/08 03:29 PM
07/11/08 03:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Early factory Street Hemis had mixture screws in the front carb so you could adjust both carbs, the '70 and '71 had the recessed mixture screws preset and the screw holes were plugged. (emissions)
Even with the factory progressive linkage the early idle mixture adjustment procedure calls for adjusting the screws in both carbs.
Re: question for anyone running dual quads [Re: John_Kunkel] #86927
07/12/08 12:26 PM
07/12/08 12:26 PM
michigan
black64 Offline
black64  Offline
michigan
I adjust front and rear on mine. Idles fine that way.
Re: question for anyone running dual quads [Re: black64] #86928
07/12/08 12:46 PM
07/12/08 12:46 PM
California
mickm Offline
mickm  Offline
California
it depends completely on the setup, but most will idle off of both carbs. the street hemis idle off of the primaries of the rear carb, the front carb did not even have usable idle circuits. but the intake manifold was designed for (relatively) equal distribution of the mixture at idle and low end from the rear carb alone.
the stage V manifold that i run now is not set up this way, and so needs both carbs set for idle for equal distribution to all of the cylinders.
i don't know, but i would imagine that most or all aftermarket daul quad intakes need both carbs idling.
Re: question for anyone running dual quads [Re: mickm] #86929
07/12/08 07:44 PM
07/12/08 07:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not so, all Street Hemi front carbs had idle mixture screws and the accompanying circuits.
The pre-'70 FSM outlines the adjustment procedure for the front carb, '70 and '71 carbs had the front carb mixture screws pre-adjusted for emissions purposes.
Re: question for anyone running dual quads [Re: John_Kunkel] #86930
07/12/08 09:57 PM
07/12/08 09:57 PM
Warrenton, VA
65Coronet7165 Offline
Warrenton, VA
Do you mind outlining that procedure John?? It would be of interest to me. I have the FSM for the 67 Chrysler/Imperial and of course they didn't have dual quads from the factory on those.
Re: question for anyone running dual quads [Re: John_Kunkel] #86931
07/12/08 10:53 PM
07/12/08 10:53 PM
S/NH
hemijimbo Offline
hemijimbo  Offline
S/NH
Not so, all Street Hemi front carbs had idle mixture screws and the accompanying circut
69 rr does not have the mixture screws in the front carb,.... it does however have an idle "speed" screw, for both f&r carbs
Re: question for anyone running dual quads [Re: dodgedart416] #86932
07/12/08 11:12 PM
07/12/08 11:12 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
My personal preference is just using the idle system on the rear. I have the CH28 with two 600s. Tried it both ways and seems to adjust and transition better with just the rear. With both idles systems being used, as the primary main system in the rear carb phases over it's idle system it may not be able to sense the front idle system as well. This is just a theory with my use and not documented as far as I know.
Russ:)
BigBlock 74 Swinger
Re: question for anyone running dual quads [Re: 65Coronet7165] #86933
07/13/08 02:55 PM
07/13/08 02:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
From the '68 FSM:
Re: question for anyone running dual quads [Re: John_Kunkel] #86934
07/14/08 06:29 PM
07/14/08 06:29 PM
California
mickm Offline
mickm  Offline
California
hmmm.... that is a new one to me. decades decay the memory, but i specifically remember my 68 NOT having idle circuit screws on the front carbs, and i though all hemis did not.
i will have to take a look. can anyone post pictures of some front carbs?
Re: question for anyone running dual quads [Re: mickm] #86935
07/14/08 10:35 PM
07/14/08 10:35 PM
S/NH
hemijimbo Offline
hemijimbo  Offline
S/NH
heres my 69 h/rr 40k 1 owner untouched front carb pic note no mixing screws...
Re: question for anyone running dual quads [Re: hemijimbo] #86936
07/15/08 02:24 AM
07/15/08 02:24 AM
California
mickm Offline
mickm  Offline
California
thats what i thought. no choke and no idle mixture screws on the front carb. and from what i remember, that was 66-71...
Re: question for anyone running dual quads [Re: mickm] #86937
07/15/08 05:18 PM
07/15/08 05:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The page I posted above is directly from the '68 FSM and instructs to adjust the idle mixture screws on the front carb. Kinda hard to do if they're not there.
Even though there are no visible mixture screws on later years they are still there under the plugs where the screws would normally be, they are preset a specific number of turns and plugged to prevent tampering with the adjustment that would affect the emissions.
