Can Parking Brake cables be "refurbished"??
#869069
12/01/10 08:56 PM
12/01/10 08:56 PM
Posts: 528 D/FW
gts95
D/FW
I'm working on a '70 Super Bee and doing a rear brake job. I've never driven the car so i have no idea if the parking brake worked or not before I took it apart...they look quite crusty as the car has sat for 30 years but not damaged, etc.
Is it common practice to clean them up with some sort of solvent and then lube them? I actually ordered some aftermarket ones thinking that would be the easier way to go, but after comparing them to the originals I just could not get myself to install them. Typical Made in India cheap aftermarket quality (they were Dorman brand cables). The spring on them was much smaller, the "fingers" that hold the cable to the backing plate and keep it from moving back were cheap and looked like they would break off easily. Just an inferior product compared to the original.
I'm not concerned about original looks really, just want a quality product. And like I say they don't appear damaged in any way, just rusty (not salt rusty though) from years of sitting.
Thanks.
1970 Super Bee, WM21, 383, auto, FY1, a/c, project!
1971 Chrysler 300 2dr, U-code, console car
1980 Chrysler LeBaron LS Limited coupe
2008 Chrysler Aspen, HEMI
2011 Ram 3500 MegaCab, 6.7
Re: Can Parking Brake cables be "refurbished"??
[Re: belv2vert66]
#869073
12/02/10 02:36 PM
12/02/10 02:36 PM
Posts: 528 D/FW
gts95
D/FW
Well I'll give it a try soaking it in rust remover and then penetrating oil.
Did the factory put any type of lube or grease on the cable?
Has anyone tried an aftermarket cable like Raybestos? Like stated I ordered some off RockAuto which were "Dorman" brand and they were inferior quality compared to the original.
[Re: gts95]
#869075
12/02/10 03:00 PM
12/02/10 03:00 PM
Posts: 75,280 A gulag near you.
JohnRR
A gulag near you.
One of the aftermarket brake line companies makes correct looking replacements , I think it's inline tube , I wouldn't waste the effort or $$ on old crusty cables .
[Re: JohnRR]
#869076
12/02/10 06:18 PM
12/02/10 06:18 PM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
I pulled the ones from my parts car.Soaked them at work in the parts cleaner.then used silicone spray on them.Been on for 5 years now and no problems.I have a 4 speed so I use them all the time.Rocky
Chrysler Firepower
[Re: therocks]
#869077
12/02/10 10:08 PM
12/02/10 10:08 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
That's the secret to keeping them working. Use them often. Our daily drivers are automatics, but I insist on using th ee-brake just to prevent them from seizing.
codfish
