How do you clean stuck fuel injectors #86893
07/10/08 06:27 PM
07/10/08 06:27 PM
Arizona
69rrconvert Offline OP
Arizona
I finally got the 5.7 Hemi installed in my 69 rr convert and it's almost ready to go. Found out last night the fuel injectors are stuck.....varnished from old gas. Had 60psi fuel pressure and no fuel to engine. Checked injectors with noid light and they are getting the signal to fire. Pulled injectors and they all smell like sour gas. Soaked them all night in lacquer cleaner. Anything else I can try or should I just get new injectors?
Re: How do you clean stuck fuel injectors [Re: 69rrconvert] #86894
07/10/08 06:54 PM
07/10/08 06:54 PM
iowa
copchaser Offline
copchaser  Offline
iowa
Garbage can time.
Re: How do you clean stuck fuel injectors [Re: copchaser] #86895
07/10/08 07:22 PM
07/10/08 07:22 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
A good shop should have a machine that can flow cleaning solution through them. I'd be concerned with soaking them in thinner, though.
Re: How do you clean stuck fuel injectors [Re: copchaser] #86896
07/10/08 07:32 PM
07/10/08 07:32 PM
Arizona
Arizona
Thanks.......you confirmed what I was already thinking
Re: How do you clean stuck fuel injectors [Re: RodStRace] #86897
07/10/08 07:33 PM
07/10/08 07:33 PM
Arizona
Arizona
I'm going to order new ones tonight. Thanks
Re: How do you clean stuck fuel injectors [Re: RodStRace] #86898
07/10/08 07:36 PM
07/10/08 07:36 PM
Maroa, Illinois
THREESIXTYDAKOTA Offline
Maroa, Illinois
They should be able to be cleaned. I have had some that were completely blocked that were able to be cleaned. Here in Illinois I am generally charged somewhere around $15 per injector. Try to find a diesel truck repair facility. They usually have the equipment. If not here is who does mine: www.gregbatesautomotive.com
Re: How do you clean stuck fuel injectors [Re: THREESIXTYDAKOTA] #86899
07/10/08 07:37 PM
07/10/08 07:37 PM
Arizona
Arizona
Thanks.......I may have them cleaned and keep for spares
