oil blowing through the valve covers on a 440?
#86872
07/10/08 06:21 PM
07/10/08 06:21 PM
my 440 runs great but it seems the oil is blowing up through the valve covers and one side is worse than the other what would cause this and how could it be fixed, any help would be great
Re: oil blowing through the valve covers on a 440?
#86873
07/10/08 06:51 PM
07/10/08 06:51 PM
Posts: 5,118 Alone in the darkness
gamagoat6x6
super street
super street
Let me guess ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) . You have no PCV system on it.
`02 RAM2500 SPORT V10 4x4
`06 GMC sierra
NO cars
[Re: gamagoat6x6]
#86874
07/10/08 07:24 PM
07/10/08 07:24 PM
yes it has what i think is a pcv hose on the back of the driverside valve cover and thats the one that gets the oil blowing, you think there could be somthing else wrong or mabye the hose be pluged?
[Re: UCUDANT]
#86876
07/10/08 07:53 PM
07/10/08 07:53 PM
ya i just noticed that post, i have the same mopar valve covers but dont no if i have baffles or not, how can i tell or where can i get them?
#86877
07/10/08 07:58 PM
07/10/08 07:58 PM
gamagoat6x6
super street
super street
Pull the PCV valve out of the valve cover while the engine is idling and see if there`s good vacuum pulling thru the valve.
`06 GMC sierra
NO cars
#86878
07/10/08 08:39 PM
07/10/08 08:39 PM
Posts: 8,157 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Pull the breather and if you see your valve gear, not a metal plate blocking your view you need a baffle
[Re: UCUDANT]
#86879
07/10/08 08:45 PM
07/10/08 08:45 PM
do you no where i can get a baffle for it? and is there a specific one i need
#86880
07/10/08 09:18 PM
07/10/08 09:18 PM
Posts: 2,069 Renton, WA
GreenBlurr
super gas
super gas
Renton, WA
I made one out of the sheet metal from one of those old Hide a Key things you used to use to hige a key in your fender etc. Works perfectly to this day hehe.
[Re: GreenBlurr]
#86881
07/10/08 09:22 PM
07/10/08 09:22 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Make sure that you have a breather on the other valve cover too. You have to have circulation.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#86882
07/11/08 06:22 PM
07/11/08 06:22 PM
so i should have a pcv valve to both valve covers?
[Re: 4spdfury]
#86885
07/11/08 11:30 PM
07/11/08 11:30 PM
if this isnt fixed will it cause problems to the motor, im gonna try to get it solved i limited my driving cos i thought somthin serius was goin wrong
#86886
07/11/08 11:39 PM
07/11/08 11:39 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Well you better quit driving it now because you do have a problem that needs to be fixed. Unless you are that ? and want to keep driving it. If thats the case why waste anyones time.
[Re: DaytonaTurbo]
#86889
07/12/08 12:51 AM
07/12/08 12:51 AM
well it has the pcv valve but no breather on the other side so im gonna try that and i gotta get some baffels and hopefully that does the trick, that hole in the piston part is what has been scaring me
#86890
07/12/08 02:20 AM
07/12/08 02:20 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
AND....if you put a breather in, DON'T get the cheapo 4.99 Chrome Mr.Gasket or similar brand breather 'cuase the stuff they fill those with plugs up real quick...like 10 runs and mine was plugged and blowing oil out the dipstick tube!! Put the old original "clean" '71 breather back on the covers and it's still going strong.....just missing that flashy chrome scene!!! I don't know what they use in those imitation breathers, but it's not much better than the cotton you find in an Aspirin bottle!!! ![](/ubbthreads/images/graemlins/laugh2.gif)
