Re: New Passon Performance 5 Speed update
[Re: JohnRR]
#867819
12/04/10 06:37 PM
12/04/10 06:37 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
The little bit I've seen online about this transmission was that it was suppose to be a "direct fit", as in not having to modify the cars panels to get it to work.
Look above at what JohnRR said, he's right, there looks to be an obvious interferance area unless something fairly significant changes. Besides, with Jamies trans you've got Jamie to deal with direct, not some no name saleman for a big company, not to mention Jamie's looks more original and will probably be stronger. No brainer decision IMO.
[Re: badblack68]
#867821
12/05/10 07:36 AM
12/05/10 07:36 AM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
I guess time will tell. I am not disagreeing, however if it's being marketed as a direct fit / no modification necessary piece, I would have thought they'd install it in a few different cars of each chassis to double check. I doubt I'll afford either one, but it sure is nice they will be available. After they are tried and proven a bit I'll likely sell off some of my extra stuff and get one (maybe two?). The thought of 4.30:1 rear gears and still being able to cruise down the highway sure is mouth watering.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
[Re: daniel_depetro]
#867822
12/05/10 10:26 AM
12/05/10 10:26 AM
Posts: 75,395 A gulag near you.
JohnRR
A gulag near you.
So was a certian other companies 5 speed swap , we saw how that turned out in more than one case.
Sorry Gene ...
#867824
12/05/10 11:25 AM
12/05/10 11:25 AM
Posts: 2,484 Answering the call of the wild
ThermoQuad
This new transmission takes these old cars to a whole new level. There should be no doubt as to the DIRECT fit and finish of this product. It should take about 2 hours if you have an 18 spline in the car already. Do that with a tremec or some other illegitimate variant If you don't know by now...I am very picky of what hardware I put on my car as it goes very fast on the roadcourse.[55 - 130 mph] Speed will hurt or worse kill you if you are not respectful of it. A bad transmission will spin you faster than you can imagine-I rode out a spinout thru the "bus stop or inner loop" at Watkins Glen in a 66 mustang track car [race car] who trans failed at about 110 mph. I was the willing passenger...I have to have hardware I can trust so I can survive my yearly driving experience. I do annual drag strip runs as well to check mph and hard straight-line performance. Tire spins and everything. 12.20-12.80 @113 mph, 3450 lbs with driver I currently have an Passon Aluminum over drive 4 speed in my pos and it has worked...flawlessy. Before the OD 4sp I had a Passon aluminum 2.66 1st gear 4 speed. Before that I had a Passon iron case 2.66 1st gear 4sp. Before Jamie Passon I had 4 speeds that made noise and vibrated the shifter handle and car. I am now closing in on a 100,000 miles of 4 speeds...now all I get is a big smile. We are talking a lot of regular miles on all of these transmissions and a whole bunch of laps at the "glen". If a more detailed endorsement is required I have on record [log book] of how many miles of road & track the Passon products have seen. Of course the info will cost money as not everything is free including transmissions from Jamie. I await the next generation transmission from Jamie like a kid on christmas eve.
[Re: 67autocross]
#867825
12/05/10 11:40 AM
12/05/10 11:40 AM
daniel_depetro
Those other guys are also coming out with a new 5 speed that's made in house, I think it's called an RS 600.
So hopefully we will have hopefully 3 to choose from!
[Re: GLR]
#867827
12/05/10 04:19 PM
12/05/10 04:19 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
all i want to know is, when exactly, can we get our hands on one? if theese work out well, i'm in for four of them.
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#867828
12/05/10 07:06 PM
12/05/10 07:06 PM
Posts: 10,687 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well now that the thread is over here lets put a price on it Do you take Richmond 5-speeds in on trade Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: JamiePasson]
#867831
12/05/10 09:10 PM
12/05/10 09:10 PM
daniel_depetro
I'm very curious to see the actual costs.
5 speed pricing info
[Re: JamiePasson]
#867833
12/06/10 08:51 PM
12/06/10 08:51 PM
Posts: 869 Sugarloaf, PA. USA
JamiePasson
Sugarloaf, PA. USA
O.K., Some pricing information. After MUCH back and forth, figuring, refiguring and trying to trim where we could without sacrificing quality, we are looking at $4295.00 for a retail price on the unit.
Now, I want to explain a little about this. This cost will cover the transmission, shifter, shifter linkage, mount plate and speedometer cable extension. This is all that is needed. Any other parts if you are switching an auto car, we can provide, but they are not needed, so therefore we didn't include them.
Please keep in mind that this unit is Made in USA. It was designed here, and is being built here by mopar people that are deicated to bringing you the highest quality parts possible. It is without doubt a premium driveline piece. All gears and shafts are made from aircraft quality 9310 alloy steel. Unfortunately, this costs money. Believe me, We are being as fair as we can on this, considering this will bolt in as it is supposed to and you are not going to have to cut your car up.
I await any further questions. Thanks, Jamie
Re: 5 speed pricing info
[Re: SCATPK]
#867836
12/06/10 09:50 PM
12/06/10 09:50 PM
Old School
Virginia Beach, VA
sounds fair to me too..now, when can i get one to try?
[Re: SCATPK]
#867837
12/06/10 09:51 PM
12/06/10 09:51 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Hi i was wondering what the gear ratios will be are the same as the HEMI trans ratio wise? Are they close or wide ratio are there going to options ? Sorry if this is off the main topic . CJ
1969 Dodge Charger
1969 Dodge Superbee
