how did you string your wiring in the engine compart? #86774
07/10/08 01:47 PM
07/10/08 01:47 PM
Andrewh Offline OP
Andrewh  Offline OP
Rewiring the engine compartment. It has a wire loom along the back firewall. I pulled all the tape off of it and so it is just in the hangers.
Just looking for ideas on bundling the wires for a cleaner look.
I don't plan on hiding it all, just wanted it to look nicer than a bunch of wires hanging.
I thought about that split plastic tubing stuff, and will probably go that route, unless someone has a better idea.
Re: how did you string your wiring in the engine compart? [Re: Andrewh] #86775
07/10/08 02:31 PM
07/10/08 02:31 PM
black plastic wire conduit does a great job of cleaning the wiring up and protecting wires from heat. It looks better than electrical tape IMO.
Re: how did you string your wiring in the engine compar [Re: Andrewh] #86776
07/10/08 02:54 PM
07/10/08 02:54 PM
places
79powerwagon Offline
places
Mine is sloppily done. It's just enough for all the systems to work properly while I do the new engine. Then it all comes out for body and paint, then it'll be done properly. I'd like to take a page from the hot rodders who hide the wiring!
Re: how did you string your wiring in the engine compart? [Re: Andrewh] #86777
07/10/08 02:55 PM
07/10/08 02:55 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
bulk wires in a convoluted tubing jacket, ran neatly under the intake manifold to choke/temp sender, down to the alternator, and horns.
the headlight harness goes thropugh the frame rail up out the end and through the square radiator support's hole.
Re: how did you string your wiring in the engine compar [Re: Andrewh] #86778
07/10/08 03:27 PM
07/10/08 03:27 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Another vote for black plastic convolute tubing...
Re: how did you string your wiring in the engine compar [Re: MoparMarq] #86779
07/10/08 05:24 PM
07/10/08 05:24 PM
Andrewh Offline OP
Andrewh  Offline OP
That does look cleaner than I imagined. Mine was kind of a mixed bag of taped wiring and that plastic stuff, but not tight and in place, just put over some areas.
